Diff drain plug
Discussion in 'Technical' started by blugene, Nov 11, 2007.
  1. blugene
    Are you saying that you can't see the pic?
  2. blugene
    Try this... :hmmm:
  3. 71gold
    ...being it's on...top... and it's in a...no run cup...
    that is the ...filler plug...:yup:
    ...:cool:...
  4. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i see it now. looks great gene
  5. blugene
    I'll be filling it sometime this week. What's the recommended fluid? i have something like 4:62s?... I'll have to look it up but it's something like that.
  6. don graham
    I'm using synthetic in mine. No problems yet. Been in for about 4 years.:)
  7. Bryant
    we use 140 wt oil. we use schaefers brand oil. you will be ok with lucas 95-140 wt. running the heavy weight oil is how we feel confident with giveng a warntee on our work. we strongly recomend staying away from synthetic oil. ive seen multiple diffs develop gear noise in about 15,000 miles when useing it.
  8. Blown 5.0
    MS.
    1974 Maverick
    I have ran the Amsoil for years with no gear noise problems. We also run the synthetic oil in our 8.8s with no noise. It also seems to make the DETROIT locker less notchey.
  9. blugene
    So the verdict is 95-140 and consider synthetic...:burnout:
  10. Blown 5.0
    MS.
    1974 Maverick
    If they are new gears and bearings i would run regular gear lube for the first few hundred miles, Then switch to synthetic.
  11. blugene
    Sounds good. (y)
