difference between 69.5, 70 and 71
Discussion in 'General Maverick/Comet' started by JHodges, Jun 2, 2007.
  1. JHodges
    JHodges thumper
    Dora Alabama
    Ok I know that a 1969.5 has the key in the tray and the 1971 has the key in the column so does the 1970 have the key in the tray or column?
  2. maverick75
  3. cookc
    cookc Member
    Indianapolis Indaina
    1976 ford maverick 4 dr. straight 6.
  4. maverick75
  5. Jamie Miles
    Late 1970 Mavericks have the key on the column.
  6. maverick75
    guess i was wrong i always though that all of them had it on thew column...
    ...hey do you know if all the 70's had the redline speedo?
  7. Jamie Miles
    Every '70 I have seen had it. I was dumb enough to pass up two of them in the junkyard a couple of years ago. The redline speedometers also have diffrent style numbers in the odometer, and the odometer has metal gears instead of plastic.
  8. maverick1970
    maverick1970 MCG State Rep
    Missouri
    69 1/2 and 70 had a drop in gas tank (gas tank is the trunk floor). 71 and later tanks mount under the trunk floor.
  9. newtoford
    newtoford Member
    New Castle Delaware
    wasnt '71 the first year for a v8 option? i know all the 69's had a 170 or 200 right?
  10. mean_maverick
    correct
  11. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    69.5 has a 7.5 rear not 8
  12. Jamie Miles
    A ton (most?) later 1970 Mavericks had 7.5 rears also, though.
