Differential I.D. ?
Discussion in 'Technical' started by mavgrab302, Apr 7, 2012.
  1. mavgrab302
    This differential is for sale locally, the guy says its a early 9" I say it's a 1966 or older 8" It's just not round enough to be a 9"... The only numbers on the tag I can read is as follows...
    Line 1 : CL-K3
    Line 2 : 25 5BA 803
    Hear is a picture, give me your opinion please...
  2. Joe Dirt
    If you can get a socket on the bottom bolt it is a 8" if you cant it is a 9"
  3. krelboyne
    krelboyne Remember
    Salem, Oregon
    That is an 8 inch housing, early one with the fill plug.
    9 inch housings have a protrusion on the back for the larger ring gear.
  4. mavgrab302
    Yes that is what I told the guy, I brought a socket set with me... it's a early 8"
  5. mavgrab302
    I thought so too but when I researched 9" diff's I found one that looks just like this 8" (no hump on the case) only difference, it was round not ovel...
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Early 9" housings(late 50's into the early/mid 60's) are smoothe and look similar to an 8".....
  7. mavgrab302
    Yes, but as far as I can tell the 8" has a defined flat spot on top and bottom and is oval shaped... the 9" has a much smaller flat spot top and bottom and is almost round... Also you can get a socket on all the nuts on the third member... It's amazing how close the 8 and 9" looks, I almost bought it but something told me to do some research first... It's a 8"
  8. rthomas771
    Here is a '66 K-code 9" rear end under my Falcon. Notice the tapered tubes at the axle flange
  9. mavgrab302
    Nice, this diff has straight tubes and is much flatter on top and bottom...
  10. baddad457
    X 2, the 57 Ford 9" I pulled from a 66 Stang parts car didn't have a bulge for the ring gear. Looked damned close to an 8" rear.
  11. baddad457
    It had a WAR case center section, making it doubly hard to ID while under the car, sitting in a muddy field. For those who don't know what a WAR case looks like, it looks exactly like an 8" center section, or an "N" case without the "N". I had to take a wild guess when looking this car over before commiting to buyin it. Fortunately the car came with a butt load of extra parts and the rear was indeed a 9". One of the best $350 parts cars I ever bought. Made a good profit on it after selling the parts that I didn't use, Then sold the car minus the 9" rear, for $400
  12. mav1970
    Can't you just simply go with the socket test on the bottom bolts of the carrier and disregard what the housing looks like - I always thought that was a fail safe test :hmmm:
  13. Joe Dirt
    Yes it is the fail safe
  14. rthomas771
    I'm guessing he wants to know how many vertical ribs
    [​IMG] [​IMG]
  15. baddad457
    And not if the car it's under is in a muddy pasture with no safe way to get under the vehicle to perform the socket test.
