Differential I.D. ?
Discussion in 'Technical' started by mavgrab302, Apr 7, 2012.
  1. krelboyne
    krelboyne Remember
    Salem, Oregon
    I did not know that. I only see them 1967-73. Thanks!
  2. mavgrab302
    On this diff you can get to all the nuts with a socket... This is a 66 or older 8" that almost fooled me into buying it... 57.5" axle to axle and 38" center to center on the spring perches, he said it came out of a mustang but I thought the perches were 44" apart on them...
  3. baddad457
    ALl Ford leaf sprung cars had a 43" ctr to ctr perch distance. Except some of the Rancheros, that's what your 8" came from.
  4. mavgrab302
    Good to know, but I didn't buy this because it was a 8" I'm looking for a 9"... Looks like I just need to buy and narrow one, I can't see myself investing the same amount of money in my factory 8"...
  5. rthomas771
    66-67 Fairlane has 44.5" between the spring perch
  6. Joe Dirt
    Negative Im not sure where you got that from
  7. Joe Dirt
    a socket will fit on a gm drop out, the 9-3/8 is way to wide to even consider the hassle to put in a small passenger car
  8. baddad457
    It's common knowledge and it happens to be true for Mavs, Comets, Mustangs, Granadas, Versailles, 57-59 fords. All these I have had in hand and measured.
  9. rthomas771
    The 9" weights 24 more pounds than an 8". Both 8" and 9" use the same axle. The area around the caps on a 9" is a lot stronger than the 8".
  10. baddad457
    Damn, where're you shopping ? There are far lower cost alternatives out there. And with the total you've got here, you've spent $1150 for an 8" and $1200 for a 9. If you're going to fork over that kind of cash, what's an extra $50 gonna hurt ? :hmmm:
  11. baddad457
    And rthomas is correct, both use the same axles. So there's no difference there.
  12. baddad457
    Nope, they use the exact same axles. If there is a difference, it's due to the bearing housing ends, which are interchangeable between 8 and 9's. You can even use 9" axles in an 8.8, if you use 8 or 9" style bearing housings. You saved $50 on a $1150 purchase and still have a weaker rearend. Try to sell that complete 8" vs a compareable 9". You won't get half as much for the 8". And have a hell of a long wait to sell it vs a 9". When Ford built the 289 Hi-Po Mustangs in 65-66, they used 8" axle tubes welded to a 9" center stamping. Those same "small bearing" 9" rears were used in many other applications. All 8" rears were small bearing equipped (as far as I know) Not all 9's had the same bearing style, there were three bearing styles: Small, (which is the same as an 8"), Large, and "Torino".
