Dim inst cluster
Discussion in 'Technical' started by RudyD, Jan 13, 2003.
  1. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    I did the white face gauge at the same time I changed the bulbs, made a big difference!!
  2. Kit Sullivan
    Kit Sullivan Member
    Inside the dash cluster are little blue plastic 'cups' that diffuse the light from the bulbs, giving them a green glow. Over the years, the little cups get hazy from heat and age and don't pass as much light. Remove and polish them, if they are not in to bad shape to begin with. If they are real bad, just take em out! I did, and lightly painted the bulbs with blue engine paint...worked awesome!
  3. Shinysideup
    Shinysideup Chillin the most
    town
    car
    Cured my dim issue with a better ground wire.
  4. MrPie68
    MrPie68 Member
    Midwest City, Oklahoma
    1969 1/2 Ford Maverick
    Hi guys, I just wanted to comment on Mavrick Newb's idea about LED's. They are a great light source that use much less amps and tend to be brighter, but as for a "dimmer" switch, you're out of luck. LED's don't "burn" like standard bulbs, they use a specific voltage/amps combo to either turn on, or not. If "dimmed", they would just turn off completely. Nice color options though.
  5. Jamie Miles
    Alto, GA
    I've had a few
    Not entirely true...
    http://mmb.maverick.to/showthread.php?t=40181&page=2
  6. mbg1973
    mbg1973 Member
    MARIETTA, GA
    1973 MAVERICK 2DR
    Advance has the leds i havent tried them but i have considered it my cluster is also very dim
  7. MrCuda724
    MrCuda724 Member
    Western PA
    A cheap cure would be to use super bright LEDs, they are about 50 cents each, they come in different voltage ratings so if you got 6VDC LEDs wire 2 of them into the socket
    in a +-+- configuration to handle your charging system, you'll know if ya got them backwards, they simply won't light.
  8. JesZeK
    JesZeK "Loyale 2.7 Turbo"
    French Harbour, Roatán. Honduras
    Mercury Comet Coupe 1969, Subaru Loyale Wagon 1985, and Wife's Kia Sephia 2000
    My Mercury Already Came New with Dimmer...
    Could you Post Pics of your Car`s Dash with Leds, Please?
    Thanx!
  9. HARRYJOHNSON
    HARRYJOHNSON Member
    AZ USA
    COMET 73
    i elimimated the ps board and hard wired everything now i have real bright dash lights
  10. mavmike72
    mavmike72 Member
    louisville kentucky
    i put 5v bulbs in mine and took the dash apart and painted the blue backgrond white it made all the difference in the world love it................
