Dirt and grime removal help!
Discussion in 'Cosmetic' started by Acedmav75, Oct 30, 2010.
  1. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    Degreaser and pressure washer then wire wheel is what I used then sprayed with 3m bed liner great stuff
  2. rthomas771
    I degreased with Greased Lighting and a garden hose then used a sand blaster then 2 coats Rust Bullet and then Dupli-Color bed liner.
  3. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    1972 Maverick 2 Door Sport Sedan Grabber
    spent countless hours removing the fender and underside junk, wouldnt be so bad had the previous body owner didn't fill every crevice with bondo as a rust preventive :16suspect
    media blasting = useless (unless its thin coating)
    wire wheel = works best but least fun :rofl2:
    gasoline = pretty good at cutting (bring plenty of rags)
    torch method (mentioned) = sounds best (y)
    Just don't first use the gasoline and then decide to use the torch!!!!!!!!!!!:hide:
  4. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    Hammer and chisel works well lmao That's what I used after the previous owner of the comet decided to slather bondo and some kinda concrete mixture all inside the damn trunk
  5. brickyard67
    brickyard67 Member
    lafayette,in.
    71 maverick
    might want to use a heat gun for the softening instead of torch lot safer,after you get the big stuff use acetone for the rest, can be bought at any hardware store in paint dept.
  6. Dave B
    You'd be nuts to use gasoline.
  7. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I read in a thread on here to use a halogen light on the back side of the panel to soften it then scrape it. Haven't tried it yet but sounded reasonable.
  8. Mad Goon
    It cleans windows and hands pretty well, just don't recommend smoking around it
    :bouncy:
