Disc Brake Swap
Discussion in 'General Maverick/Comet' started by JustInARace, Feb 7, 2020.
  1. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Thanks. No I had newer lug nuts. I left them for someone else.
    EDIT: Looking at caps. Need to stop myself and remember, these are temp rim solutions.
    Rim width Minimum tire width Maximum tire width
    7,0 Inches 195 mm 225 mm
    Id like something a little wider in the back, I think?
  2. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Yep, same here(y)
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Stop it they are temp rims.......
    BBMS18 likes this.
  4. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Done
    BBMS18 likes this.
  5. BBMS18
    BBMS18 Member
    75 Comet
    I’m here to be a BAD influence :evilsmile:
    I like those painted to match(y) If you pay the shipping I’ll send ya a set of caps.
    9E02F94B-87DF-4CC5-8B3D-CE02D1145DC2.jpeg 6FA66C5A-C725-44CB-92F8-181DDEA84F40.jpeg
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Deal DM me with how much to 44256. The 225/70 rubbers rub on the bump and trac, but still would like to have the caps if I just end up going with thinner rubber
    BBMS18 likes this.
  7. BBMS18
    BBMS18 Member
    75 Comet
    It may take me several days to make it to the post office, I’ll give you a shout when I do.(y)
    smegnl likes this.
  8. Hotrock
    Munroe Falls, Ohio
    Wouldn't a spacer fix that problem?
  9. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    yeah, i was looking at those. Im trying to keep it on the cheap as Im not using these perm. Plus I dont even know what gonna happen when I try to shove 15" 225/70 under the front.
  10. BBMS18
    BBMS18 Member
    75 Comet
    My 235/75R15’s don’t hit the bump stops, I’ll try to get some pictures in the next couple days.
    smegnl likes this.
  11. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I wonder if the diff is you have 7" rims and I have 6"
  12. BBMS18
    BBMS18 Member
    75 Comet
    I’ll measure the wheels when I take the pictures.
  13. BBMS18
    BBMS18 Member
    75 Comet
    The widest part of my 235/75R15’s (side wall) is 1-3/4” from the wheel lip.
    On the inside, side wall is 1/2” from the inner wheelhouse and 1” from the bump stop.
    My wheels are 7” wide, are you sure yours are 6”?
    I haven’t forgot about your shipping quote, been busy getting read for the coming snow.
  14. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    No rush on the shipping.
    I am not positive about the 6", but https://www.wheel-size.com/size/ford/ranger/2001/ shows 225/70 on a 6" and 235/75 on a 7".
    For only 18$ a rim/tire, i may go back and see if I can find two 235/75 and see if they fit better.
    BBMS18 likes this.
