Disc break spindals
Discussion in 'Parts Interchange' started by papawfalcon, Oct 6, 2019.
  1. papawfalcon
    papawfalcon Member
    Southern Illinois
    I have a set of 5 lug disc break spindals (have 4 lug on my car) that I would like to use but want to stay with drum breaks. Can 5 lug disc breaks spindals be used with drum breaks.
  2. Krazy Comet
    Nope...
    AFAIK other than '67 Fairlane & Mustang disc/drum spindles, all the others are specific to type brakes used.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    And WHY would you want drum brAKEs???
  4. papawfalcon
    papawfalcon Member
    Southern Illinois
    THANKS I know why because new master cylinder and all new lines wheel cylinders shoes and everything rear and save money.
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Save your money and put GOOD brakes on the car.
    FishnRace and mojo like this.
  6. Emil
    Emil Member
    California
    1970 Ford Maverick
    Can anyone point me in the right direction, I need a front passenger side Spindle (4 lug) for my 1970 Mavi. Thanks.
  7. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Craig Selvey likes this.
  8. Emil
    Emil Member
    California
    1970 Ford Maverick
    Will do, Thanks BBMS18
    BBMS18 likes this.
  9. Krazy Comet
    Lug count has nothing to do with spindles.
    Except for '69½, a drum brake spindle is a drum brake spindle. What you need to know is it a '69½ or true 1970. Even those can be swapped by using correct bearing.
  10. 71gold
    :Welcome:...:Handshake:
    Emil likes this.
  11. Emil
    Emil Member
    California
    1970 Ford Maverick
    Ok, I'll have to verify the date of production. So far I haven't found any that resemble exactly the spindle on my Mavi. Thanks.
  12. Krazy Comet
    For true '70, drum spindles interchange up to '74(last year of drums). Also same spindles were also used on '70-'71 Torino & Montego, plus '70 Mustang & Cougar. The 69½, interchanges with above vehicles from '69 back to '67, plus Falcon.
    Info from Hollander Interchange & double checked with Ford Master Parts Catalog.
    Crazy Larry likes this.
