Distributor Frozen
Discussion in 'Technical' started by coutangman, Dec 29, 2009.
  1. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I broke the housing on the Torino GT I used to have prying on it. Unless you have a back up be patient and work it but don't force it. My GTO had a place on it where you could use a wrench (couldn't get to it in the car:hmmm:) but those distributors never deem to get stuck like the Fords do.
  2. rthomas771
    Put dry ice on the distributer housing and use some thin wood shims to try to insulate the block from the baggy Let it sit a few hours then try to work the distributor loose.
  3. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    I like the ice idea. I ve had some luck with socket on crank an turn eng backwards. The cut of gears push dist. up
  4. 71gold
    my thinking is....if the dist. is this stuck, what makes you think the timming has moved. could it be something else that needs to be addressed first and then deal with the dist...:huh:
    ...Frank...:tiphat:
  5. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    I agree with Frank on this situation. It could be something else wrong.
    As far as getting it out, I've tapped on the vacume advance both ways with a hammer and also used turning the motor over with a socket to try and force it up.
    Does it move at all either way, or is it like it's "welded" to the block
  6. justin has a 74
    kentucky
    Mine was like that but thanks to a pry bar and redneck enginering, we got it out, i would not recomend an engine hoist but....
  7. Dave B
    A little heat and a candle sometimes works.
    My friends Jag had some suspension parts seized, aluminum to steel. I heated them up, and pressed a candle to the spot where the joint was, the wax penetrated, and we got it apart. He had tried for days to get the parts to separate, along with someone before him.....seemed goofy, but it worked, I forget where I read about it??
  8. 71gold
    ...need to add this to...homemade tools and tricks...:thumbs2:
  9. Andysutt
    Conway Arkansas
    1972 Comet GT
    The candle trick works great on rusty bolts.
    I didn't think about it for the distributor. Good call Dave
  10. maverickmadness
    maverickmadness Member
    ala
    1973 maverick grabber, 1972 maverick grabber,1974 maverick grabber,
    if timing is off and cant move dizzy sounds like timeing chain may be strecthed. sounds like dizzy never been removed so i bet chain hasnt been changed out either .just my 2 cents.
    the p b blaster and love taps usualy work for me. but if a factory dizz, they are not expensive to replace if you break it. hope you get it to move. and like the candle idea . never tryed it . have tryed ice and didnt work.
  11. Jeff S
    Jeff S Member
    NoVA
    none
    I could picture you lifting the whole front of the car off the ground by the distributor :rofl2:
  12. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Jim,
    Did you get it out?
    Jim
  13. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    last I heard,,, dist. stayed put but engine fell down!!! j/k
