Distributor, Ignition Coil and Electric Choke wiring question
Discussion in 'General Maverick/Comet' started by rag9836, Nov 13, 2016.
  1. rag9836
    rag9836 1972 Comet, 67K
    Riverside, CA
    Comet
  2. Krazy Comet
    I trigger the Painless Wiring fuse panel relay with coil feed, fuse panel then powers ign, electric fan etc...
    71gold, Paul Masson and Hotrock like this.
  3. rag9836
    Riverside, CA
    Comet
    That looks nice. Thanks for all the help guys
  4. Hotrock
    Munroe Falls, Ohio
    Krazy Comet, that is pretty!!!!!!!!!
  5. modmav
    modmav Member
    Jamestown ND
    You need a full 12 volts for the pertronix, I run my coil and electric choke off relays one for each used original coil wire to trigger the relay and getting power directly off the battery. like Tom said only feed one thing per relay but you need at least a 30 amp relay for coil choke could be less but why, ground the choke to carb itself, you may be missing the 12 volt crank only wire to coil, also I see the pos coil wire running to the dr side, the length of resistor wire is dependent on the total length of wire from ign to coil, if you add another 2 feet will drop your voltage even more,as I understand, even so the pertronix needs 12 volts and no less,
  6. rag9836
    Riverside, CA
    Comet
    Learning things the hard way here. Hooked up the pertronix relay... 11.3 volts to coil? Dumbfounded. Multimeter shows 12 going in, nothing else hooked to coil. Test the ground of coil off the battery, 12 volts. Test the positive off coil, 11.3.
    Not sure what my next step is. Try a new relay and coil?
  7. modmav
    modmav Member
    Jamestown ND
    you installed a relay for the coil and have 12 volts in to relay and 12 out but 11.3 off pos side of coil is that correct
  8. rag9836
    Riverside, CA
    Comet
    Correct
  9. rag9836
    Riverside, CA
    Comet
    Issue was distributor... now I get to wait.
  10. modmav
    modmav Member
    Jamestown ND
    dont know for sure but with the hot wire connected to the coil with the ign on there may be a small voltage drop at that point. the pertronix coil will operate from 10.5 t0 16 volts if I remember correctly but not 6 to 9 like stock point coil
