Distributor questions?
Discussion in 'Technical' started by Flipz, Oct 10, 2021.
  1. Flipz
    Flipz Member
    Arkansas
    74 Maverick
    So I'm using a 98 Explorer 302 but switching it to carb. Can I re-use the distributor or do I need to replace with something designed for carb?
  2. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    98 Explorer has a cam synchronizer, you will need to replace it with a distributor. Make sure the distributor has the correct cam gear.
  3. Flipz
    Flipz Member
    Arkansas
    74 Maverick
    Where would I start lookin for that info?
  4. BBMS18
    BBMS18 Member
    75 Comet
    Right here of course.
    Remove the cam synchronizer from the Explorer engine and inspect the gear.
    Gear on the left is cast iron (rough finish) steel gear on the right (smooth finish)
    Buy a distributor with same type of gear as the Explorer or change gear as needed.
  5. ADOR
    ADOR Member
    Northeast Louisiana
    1972 Comet Gt
    If you want a dura spark 2 distributor with the roller cam gear on it get a distributor from a parts house new for a 1985 mustang GT with manual trans.
    The automatics had efi and flat tappet cam.
    the manual cars had a Holley 4v with roller cam from the factory.
    (Double check but I do believe I have my year correct)
    Hotrock likes this.
  6. ADOR
    ADOR Member
    Northeast Louisiana
    1972 Comet Gt
    Krazy Comet and BBMS18 like this.
  7. Hotrock
    Munroe Falls, Ohio
    (Double check but I do believe I have my year correct)[/QUOTE]
    You are correct. That is the exact distributor I run.
