distributor upgrade electronic IGNITION help
Discussion in 'Parts Interchange' started by pacolobo, Jul 9, 2015.
  1. rthomas771
    Pertronix is a downgrade from the Duraspark.
    Krazy Comet likes this.
  2. 71gold
    ...but a whole lot better than points...:yup:
  3. rthomas771
    A heck of a lot better than points :yup:
  4. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    I replaced my point distributor with a 1976 Duraspark. (Bought from NAPA). Previously, I bought a REAL junker with the control module from an auto wrecker - was dirt cheap - didn't work. I used the distributor for the core (That's where I got my money, back). I "gutted" the control module, and put in a GM HEI ignition module.
    Works great!
  5. 70GreenMonster
    70GreenMonster Member
    Space Coast, Florida
    We replaced our crappy original Load-O-Matic with a Performance Distributors D.U.I ignition in our 65 Falcon 170.
    It has been great!
    No ignition box, no points, no condenser, no maintenance, just 1 vacuum hose and 1 wire run off the ignition switch and go. Don't use the hot wire going to old distributor because it goes through a resistor. We did have to make a new oil pump drive shaft (comes out of the bottom of dizzy). We just cut a long allen wrench to the right length. The factory oil pump drive shaft is 1/2 inch too short. We get a big hot spark and it starts easy and improves the big dead spot in the middle of the torque curve. It wasn't cheap...almost $400, but worth it every time it starts right up. IMG_20150320_104632.jpg
  6. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    I use one of those on my 400 Ford not because I thought it was good but because The only two distributors that would fit My engine with the intake spacer plates was a HEI or a MSD, I have had bad luck with My MSD and will not waste money on another one!
  7. Krazy Comet
    Dismal Swamp
    The chance I'd ever use a GM dist in any Ford is zero & none...
    Except for Buick, at least on most GM V8 or V6 engines it's hidden out of sight on rear of engine...
  8. Mavit
    Mavit Member
    Prince george bc
    I like a distributor that makes my engine run , The stock duraspark distributor would not fit into the engine because the manifold was in the way I used a MSD 6 for 3 years but in three years I had to replace the box three times!
    It was cheaper to buy a HEI for my ford than to buy another box so I bought the HEI! As far as performance goes my My car runs the same times at the drags as with the MSD and I run a full season without replacing a box!
  9. Maverickmike73
    Maverickmike73 Certified Wire Tie Tech
    pittsburgh
    1970 Maverick Grabber
    just put a hei distibutor in my 302 and love it runs just fine
  10. bmcdaniel
    And it's so easy to tune and adjust there....
  11. bmcdaniel
  12. rthomas771
  13. bmcdaniel
    So you don't need to set the ignition curve, it's just magically right for every car?
  14. Mavit
    Mavit Member
    Prince george bc
  15. rthomas771
    They are from a AMC purist. If you read the links it does make sense.
