Distributor Upgrade
Discussion in 'Technical' started by Mlover, Dec 2, 2019.
  1. fullcm
    fullcm Doug
    Michigan
    74 maverick
    I just read on some other posts that the wire itself has a resistance built into it. So it sounds like the entire length of that wire would need bypassed??
  2. fullcm
    fullcm Doug
    Michigan
    74 maverick
    Not sure, I have read in here that some guys prefer the duraspark system.
  3. mojo
    I would install spark plug wires repair the frayed wire at coil, leave the DSII system alone, replace rotor and cap. I been running the DSII for 10 yrs and 20K miles w/o issue. I gap plugs around .45. I can see the rotor is in need of attention/replacing. I carry a spare DS module on road trips and have never need to remove from box. It's a reliable system for a car not needing regular high rpm/racing ignition.
    Mlover likes this.
  4. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    Thank you! Would it make sense to add the Flamethrower 1 coil to my current setup?
    Second. The system that I currently have installed is the Duraspark I or the Duraspark II?
    Thank you all for the input and knowledge! Appreciate all the help! Would not have a running car without y’all!
  5. mojo
    I'm not sure/familiar w/ the coil in question and if it's compatible w/ the DS systems. They may/probably need full 12volts to function properly whereas Ford uses resistance wire in system lowering voltage approx. 8 volts or so. I would check w/ Flamethrower mfg to be sure.
  6. Krazy Comet
    Coil is mostly a matter of choice though unless you have a Hi-Po engine, I doubt you'll notice any improvement over stock Duraspark coil(maybe if it were failing). I have no idea how low of resistance HP coil the DS will tolerate.
    Assuming the Duraspark is original to car it's no doubt a DS-I. I believe '74 Calif models were the first use of system.
  7. Powerband
    Powerband Member
    NY's \H/
    Good note...
    DS-I used 'Points" type/same distributor cap and wires, DS-II uses the bigger 'Grey/Blue" cap with Pin connectors and different wires.
    250 with DS-I with GM HEI trigger
    250 with DS II and HEI Ignition Module (programmable RPM limiting -
    https://www.summitracing.com/parts/pnx-d72000 )
    have fun
  8. Hotrock
    Munroe Falls, Ohio
    Powerband, think you have enough CFM capability for that 6 cylinder? That is wild!!!!
  9. fullcm
    fullcm Doug
    Michigan
    74 maverick
    wow thats impressive! I would like to get some more performance out of my 250 since I really want to keep things orignial but don't know where to start.
