Ditching power brakes...
Discussion in 'General Maverick/Comet' started by 408w-maverick, Nov 19, 2012.
  1. Craig Selvey
    You will need to change the inside pedal as well. The power brake pedal does not push the rod straight. It pushes the rod at an angle.
  2. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    Alrighty so im gonna get the wilwood MS & its pushrod threw summit then i have to get a maverick nonpower brake pedal set up...Winter is gonna be long lol
  3. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    If you need the non power brake setup (mount and pedal assembly) I have a few just sitting on the shelf ready to put in a box and send. PM me if you are interested.
  4. 408w-maverick
    Oklahoma City
    Thanks man ill send ya a pm when i get some money lol switiching jobs right now so aint spending anything on the car til everythings done
  5. Joe Dirt
  6. Fordmaster169
    Coos Bay, Oregon
    No problem, I have a few so at least one will be here when you need it.
  7. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Russ, I looked that number up and they show both ports to be 3/8-24 and the bore to 0.875"?
    I'm swapping my m/c out for a 1" bore, I have a Corvette C3 master right now but the mount holes will need elongating and the ports are 1/2-20 and 9/16-18...
  8. scooper77515
    Just looked at JEGS, check out part number 260-8555-PK
    Comes with an adjustable proportioning valve, brake line, and all the fittings.
    It was a hassle for me to find the lines with the correct sized fittings, that would fit the M/C on one end, and the line-lock at the other.
    1" bore on mine.
  9. 408w-maverick
    Oklahoma City
    Freakin sweetage thanks scoop thats what i need im re doin all my lines ive got a really really really small leak in my factory hard line
  10. Joe Dirt
    Dont know whats going on, the number was for a 86 ram van master cylinder 1.25 bore with the right ports ive got one on my 4 door also
