Diving into a 302 swap project 1970 Grabber
Discussion in 'Maverick/Comet Projects' started by Run Free1_70, Jun 5, 2015.
Thread Status:
Not open for further replies.
  1. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    1970 Maverick Grabber 200/six, swapped to 306ci
    I am interested in the stands, Big Dog.
    Just feeling PM handicapped ATM.
  2. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I think I sent you a pm....not sure I did it right
  3. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    I have an update on the 85 lincoln 302...
    It had a fatal flaw of a broken off water pump bolt.
    Someone broke off 2 drill bits on each side of the bolt.
    I didn't know until I took off the timing cover, broke flush.
    As I was taking a week to patiently drill out the problem area.
    When I was tapping for a helicoil, is when it happened...
    The entire side of the water jacket next to the bolt hole, broke out.
    Long story short, I angrily put the motor on a Jenny Craig Diet.
    Stripped it down from 460lbs to 130lbs, now just a bare block.
    Good news is, my buddy is selling me a complete 306 tricked out.
    I estimate 330hp to 345hp, will be taking pics eventually.
  4. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    I consider this experience as an expensive lesson to thoroughly inspect purchases.
    In the particular case here, it was about a $600 lesson.
  5. Krazy Comet
    While broken bolts are fairly common, can't say I've seen a block have a chunk fall out of it unless it'd been frozen...
  6. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    I think it may have been galvanic corrosion from dissimilar metals (drill bits) in an iron block.
    Using the antifreeze as an electrolyte, the drill bits corroded the iron around the area.
    Which explains why the block spit out iron granules(sand), instead of metal shavings.
  7. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    I have to scrap the block this weekend, I'll take some pics of the damage.
  8. alaskamaverick
    alaskamaverick Member
    Spokane, WA
    RunFree1_70,
    Welcome to the Maverick world...I know everybody has their own vision, good lord I have mine. :2cents: If I were to do it all over again, crate engine. I guess it all depends on how deep your pockets are.
    I too am in the process of installing a V8 (1981 Lincoln Continental), I ended up finding a cheap 74 Maverick donor car which helped out tremendously. I used/took everything off of the 74 I could.
    Best of luck on your build.
  9. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    Nice, did the lincoln come with a 2 or 4 barrel carb?
  10. Eli Lacy
    Eli Lacy Banned
    1970 ford maverick(grabber clone)
    The 70 grabbers had them, we parted out a 70 grabber and it had it.
  11. Krazy Comet
    Other than 1st year 1968, Boss 302 & '83-'85 Stangs, there was never another 4bbl 302/5.0 from factory...
  12. alaskamaverick
    Spokane, WA
    I bought it as a long block, no intake or carb. I put a edelbrock performer intake and a 500cfm carb on it.
  13. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    If all goes well this week, I will have my 306 by Friday.
    A motor far more photogenic for future posts:burnout:
  14. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    Did I hear something about, "if you Joe Dirt your I-6 mounts they can crack"...? 0712151612a.jpg I managed to get all 3 bolts in
  15. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    Here is the 306, swapped the offenhauser that was on it for an edelbrock.
    0807151157.jpg 0807151157.jpg 0807151201.jpg 0807151201a.jpg 0807151438.jpg 0807151439.jpg 0807151439a.jpg 0807151439b.jpg
Thread Status:
