Diving into a 302 swap project 1970 Grabber
Discussion in 'Maverick/Comet Projects' started by Run Free1_70, Jun 5, 2015.
Thread Status:
Not open for further replies.
  1. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    1970 Maverick Grabber 200/six, swapped to 306ci
    Looking more like a complete engine.....
    0907151758.jpg 0907151758a.jpg 0907151758b.jpg 0907151758c.jpg 0907151758d.jpg
  2. 70GreenMonster
    70GreenMonster Member
    Space Coast, Florida
    Sweet!! Are you going to reinstall the shock tower bracing?
  3. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    Yes, definitely.
  4. CaptainComet
    Just read through the whole thread ... nice starting point! Clean car.
    Regarding the 8 inch rear ... if you want 5 bolt wheels, you will need to swap the whole axle anyway. The bearing sizes in that one are different than the 5 bolt. Center chunk is 28 spline like other factory 8s.
  5. 70GreenMonster
    What trans are you installing? C4, FMX, or AOD? I just inherited my son's freshly built 175 (bored 170) with upgrades because of a wreck and can't find any way to bolt any kind of automatic overdrive trans to it. I really want an overdrive trans, but have the small six with high mount starter. Guess I'm stuck with a C4 unless I switch to a manual, ....then my wife won't like to drive it. It's for both of us to drive, so she has a lot of input on the build. I hate to waste all the time , effort and expense we put into our Falcon motor. block almost ready to go back in.jpg bored .030 and all new pistons and rings.jpg 175-big log-Weber DGV-DUI.jpg
  6. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    I finally have some pictures of the mav just after returning to my back yard. 20150909_183233.jpg
    This was before wiring up the engine, and bay....the plug wires look like spaghetti at the moment.
  7. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    Also, scrubbed up the original six alternator and starter relay with a toothbrush.
    0923151439a.jpg 0923151440.jpg 0923151439c.jpg Had to rig up a redneck alternator spacer from an old deep well socket. 0923151439d.jpg
    A sleeping beast, just waiting to awaken...and hit the street.
  8. 71gold
    Purty...:yup:
  9. Krazy Comet
    Dismal Swamp
    Really nice...
    BTW the fan spacer is supposed to be natural aluminum, never seen one painted on any Ford from factory...
  10. 71gold
    breather and valve covers blue also...
  11. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    Having some doubts with wiring up the duraspark system into my '70.
    I believe I have everything worked out, did a lot of research online regarding the system.
    Mine is green grommet, btw and has a blue wire in with the white/red combination.
    Also, the wires are backwards plug to plug on the distributor side...but the plugs fit.
    I wired in a 16g wire from the ignition pink to red/yellow stripe connector just short of ignition switch.
    That wire will serve as my run only wire for red to brainbox, as white I assume goes to S terminal on start relay.
    Still utilizing the resistance wire for coil power only, the system was supposedly in a 1976 Maverick 302.
  12. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    Tom, the spacer was painted black to keep with the sleeper theme.
    Frank, the Edelbrock chrome covers only serve as a temporary solution.
  13. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    Anyone have a 1970 drop in style gas tank for sale?
    Someone fiberglassed over holes, and tears galore on mine.
    Radiator shop can't even fix.
  14. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi Larry:
    Just finishing my 70 Maverick and it came with an 8" rear with 4-lug wheels.. Doesn't look like a "transplant"
    I just changed the hubs to 5 lug and cleaned and put in new grease in the rear with new seals and axles. Haven't drove
    it yet .. have to install the seats and windshields .. everything else is A OK and ready to roll.
    Cometized
    (Chip)
  15. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Yeah, I got educated on that earlier in this thread.
    Ya learn something new every day.
Thread Status:
