Dixie Mavericks at the Moonshine Festival
Discussion in 'General Maverick/Comet' started by dmhines, Aug 26, 2007.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    FYI ... Frank ... I am using all the factory connections. The coil wire with the original yellow boot is plugged into my Pertronix coil ... then the red wire from the Pertronix is also hooked to the the same post.
  2. Craig Selvey
    Me too. It required a nut under the little yellow boot to clamp down the eyelet for the Pertronix. I had to grind the nut down about halfway to give me enough post to shove the yellow boot on.
  3. 71gold
    could you check and see if it's...full 12v s/on...mine is 9.34v s/on...
    thanks...:burnout:
  4. Craig Selvey
    Mine was 12 volts on.
  5. Earl Branham
    Lugoff, SC
    Frank; I'll check mine and let you know.
  6. Jamie Miles
    Alto, GA
    I've had a few
    Wish I could have made it. I was up real late Saturday night trying to finish the install of the 200 into the '72, to find that the header hits the frame with the 200 vs. the 250 and the transmission I put in was dead. I gave up at that point, slept in Sunday morning and got up and swapped the transmission in time to head home Sunday night. On the upside, the '72 is now powered by a '71 200 with 31,000 original miles on it. Good to go for another 200,000+ miles. :)
