Do da slick fit da wheel?
Discussion in 'Drag Racing' started by Hawkco, Mar 22, 2006.
  1. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Synopsis,, I think Earl told Terry to screw his slicks.....:rofl: :bananaman
  2. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    He was under the evil influence of Frank.:evilsmile
    bossmav, that was a good article. I had read a similar one somewhere else. Wish I could remember where.:hmmm: These slicks will be used on car that will not run faster than in the 11's (I hope).
  3. Maverick Man
    California
    really never had one?
    called foot brake can burn though all gears in the water box :p
    my car must not have enough power :cry: or maybe my front brakes are really good :D or maybe my back brakes suck! :49:
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    :hmmm: Maybe this has happened to you personally, but I (and many others at the track w/out a line lock) have had no problems at all getting the heat into the tire. Normally, it doesn't take a John Force burnout to get the tires up to temp.
    Waterbox, pull forward, powerbrake, start off in low, get the rpms up, shift into second and get the rpms up until you see the tires start to smoke, then let off the brakes and let the tires 'grab' the track before pulling up to the starting line.
    Plenty of my buddies (with relatively fast cars) do the same thing.
    I'm not saying a linelock isn't a good thing - I'm just saying that NOT having one will not prevent you from ever getting the tires hot enough.
    Maybe this is one of those "Let's agree to disagree" things. :beerchug:
  5. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Uh, Derrick and Rick, Dennis was telling me I needed a line loc because my '73 is going to be running a manual transmission. It's a little hard to manipulate a clutch, brake, and gas pedal with two feet. I know it can be done, but a line loc makes a burnout with a manual tranny whole lots easier.:yup:
  6. Rick Book
    Rick Book Member
    Thailand
    I agree, Terry - but it's a matter of "finesse" to get the 'power-braking' down on a manual tranny. It's done by many.
    Either way, best of luck to you. Can't wait to see your posts about the nights at the track.
  7. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    I'm sure you haven't noticed but, I ain't built for finesse. :drive:
  8. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Found some 14x8 wheels
    Bought a pair of 14x8 chrome reverse off e-Bay with 3.5 inch backspacing and the Ford bolt pattern - no unilug. May have paid too much - both wheels, plus shipping from WA, was $69.95. I like the fact that they are steel wheels.
  9. don graham
    wtg. sounds like a steal wheel to me.:)
  10. stmanser
    Davenport, Iowa
    hawko.... you said the 14x8 rims are all over the place... are these 4 lugs or 5 lugs?
  11. Earl Branham
    Lugoff, SC
    They are 5 lug, Simon.
  12. Hawkco
    Rex, Georgia (GA)
    77 Maverick
  13. Rick Book
    Rick Book Member
    Thailand
    Why so, Terry? Lighter = Gooder
  14. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Easier and more reliable to balance than the old style aluminum wheels (have to use stick on weights), take more abuse (I.e., being tossed around in the truck, trailer, from one side of basement to other), and cheaper.
    Besides, when I sit behind the wheel, I'll be adding 250 lbs to the weight of the car. So what's another 3-4 lbs?:D
  15. Rick Book
    Rick Book Member
    Thailand
    Ha! Good point(s).
