Do I really need MSD 6A?
Discussion in 'Technical' started by scooper77515, Jun 9, 2012.
  1. tody
    tody Member
    cologne, germany
    and moisture.
  2. Jamie Miles
    Alto, GA
    I've had a few
    Mine has been mounted right here on the left front fender apron for ~130,000 miles. Car is a daily driver and sits outside year round.
      File size:
      448.8 KB
  3. mav1970
    Maybe Radio Shack still sells those nice brushed aluminum hobby boxes in various sizes that would look much better than a bulky plastic battery box. I built the electrical portions of bucket trucks and digger derricks for Altec Industries at one time and some of the stuff we built was in housings such as this type.
    Put the cover on and everything disappears :dance:
  4. mav1970
    Do these boxes give off any heat?
  5. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    They don't realty give off any heat but if I'm not mistaken the msd instructions say it souls be mounted away from heat and moisture.
  6. baddad457
    B.S. Where'd you get that info ? Mine's good to the motor's rev limit of 7 grand. I've seen a Duraspark throw a spark three feet across a 400.
  7. Resto
    Resto Benders Evil Twin
    Yuma AZ
    OK....If....You want clean? This is where Im going. 302ford380x285.jpg If one considers the cost of all the MSD components, this set up is cost effective. The stats on spark duration and amps are way better. IMHO. This is one step below a crank trigger. "We dont need no stinking Rev Limiter"!
  8. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    I run a 6AL just for the rev limiter.Being a stick and the fact i drive it hard it's nice insurance.Car runs 12.80s with or with out a MSD box makes no difference on a mild engine.A MSD distributor uses a Duraspark magnetic pick up, the only advantage is tighter tolerances makes a more accurate distributor.
    A good friend of mine has a 69 Nova 427 bracket car runs very consistant 10.70's with a MSD 6al and distributor.One big event the car had ignition problems and we had limited time to fix,he pulls out a HEI dist from his trailer with welded weights in it ,stabs it in the Nova and the car runs the same 10.70's.
    Now with that said i'm not saying the stuff is junk just not always needed
  9. 71gold
    on a...low compression engine...it needs to be under the hood...it's only...WOW factor...:huh:
  10. Fish OutOfWater
    Fish OutOfWater Brian
    Long Island, NY
    Black. Red. Silver. Very nice!
  11. strokermaverick
    strokermaverick Member
    WOW!!!:thumbs2:
    I am sure your motor will turn 7,000 rpm, with the duraspark box. But, what you are failing to realize is, the voltage of the Duraspark box, dropping off after 5,000 rpm, where the MSD, does not. I stand behind my previous statement 100%. So, what we have here is, a case where you haven't done your homework. So, I am not B.S.
  12. 71gold
    Edelbrock...cast the mounting bosses for my MSD box into the intake...:huh:
  13. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Yeah, but that's that other brand engine. :D
  14. baddad457
    That's your opinion. Mine doesn't miss a beat above 5000. Try it. As long as the fire is lit, when it needs to be lit, voltage doesn't matter.
  15. strokermaverick
    I'm sure you get fire above 5,000 rpm, but it is not what it could be with a superior ignition system, such as MSD.
