Does 5.0 power steering pump mount directly to block, or is there a bracket?
Discussion in 'General Maverick/Comet' started by scooper77515, Mar 6, 2013.
  1. scooper77515
    And make it 20 pages long!!! :biglaugh:
  2. 71gold
    ...yep...:yup:
  3. Krazy Comet
    Yep smog pump even on EFI, were plumbed into ports on the back of the heads... Easy enough to toss and just use a shorter belt... Driver side requires a non-A/C bracket to mount the P/S higher if A/C isn't used...
    There was also a two belt setup with std rotation water pump that swapped positions of the alt and A/C, those were used on full size models(Crown Vic, Grand Marquis, etc)...
