Dome light/map light
Discussion in 'Technical' started by leeinphx, Feb 6, 2023.
  1. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Was cleaning up parts to get them ready for the spring reasembly and decided to get to some small interior bits. The dome light lens had the heat burn from those hot dome light lamps. So was pretty frustrated finding a replacement. Found that if you do a general search, not maverick specific, they are out there for well under $10 delivered. The dome/map light assembly was used for a lot of years and appears to have been universal across the models.
    My chrome piece has some pitting and rust, but I think it should clean up. LED lamps are in the works to prevent the burn on the replacement.
    Shorty likes this.
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    The dome light skid mark is very prevalent and one of the reasons I swapped to LED. I think you will be pleased.
    Shorty likes this.
  3. 71Mavrk
    71Mavrk Member
    Nevada
    My strip model did not come with the LDO light. I had to modify the roof mount to get it to work. Thankfully, I grabbed the wiring harness too. So it all plugged in. I went with LEDs too. It is a much nicer light that the poverty dome light that she came with. They did use them on several models. I use to see them in the junk yard all the time.
    Micah
  4. 71gold
    you mind sharing where you got the replacement lens . the one I found was a real close fit but wouldn't snap in and lock.
  5. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Hmm, I ordered it and will update on its fitment as soon as it arrives.
    Here is the one I ordered.
    https://www.ebay.com/itm/285055945420
    If it doesn't work, I wonder if the screw holes on the chrome part are the same with the newer ones. Mine isn't in great shape, so I may try to find a newer one that the lens will fit and see if it will go on my base. Or find one with the base and see if it will match up to the wiring. The power was quite interesting. The ends of the wires snap into holes, and the screws that hold the base make contact with the leads, and hold up the base all in one step.
  6. Acornridgeman
    Wisconsin
    Local auto parts store should be able to get them too - DORMAN 74351
  7. 71gold
    IIRC that is the one I got.
  8. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
  9. 71gold
    CLEAR Ford Dome/Map Light Lens Replaces C5AZ-13783E, 74351, 47-4291 Mustang F150
    seems to fit about anything Ford...LOL
  10. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Whoohoo.. Fit perfect.
    D2LY-13783E
    Just to close this out if anyone reads this in the future and wants to update to the map light, I attached a pic of the wiring. If you get a salvage yard light, definitely grab the pigtail as it is used for supporting the light (like a drywall anchor does) as well as powering it.
    old55guy and jasonwthompson like this.
  11. 71gold
    went to Summit today and ordered a
    ... DORMAN 74351 lens...Summit # RNB-74351..$ 6.99
    fuel sender...71-73 mustang...TNK-FG87A...$49.99
    picked up a couple of other items while I was there...:thumbs2:
    Russell likes this.
  12. Krazy Comet
  13. 71Mavrk
    71Mavrk Member
    Nevada
    I will add to this for those who have earlier models. You will need to cut two squares into the roof brace to allow for the electrical connection mount.
    Micah
    Russell and leeinphx like this.
  14. 71gold
    tried to install the lens tonight...It fit but the tabs wouldn't lock in. I'll try again tomorrow.
    old55guy likes this.
