Door lower seals
Discussion in 'General Maverick/Comet' started by fullcm, Feb 7, 2019.
Tags:
  1. fullcm
    fullcm Doug
    Michigan
    74 maverick
    I just purchased a set of the rubber lower door seals from AutoKrafters to install this spring. I have seen a lot of posts mentioning that these are too thick and cause the door to be difficult to close. My original seals are in decent shape and I am really just changing them out for cosmetic reasons so if they are not going to work well I may not want to do it. The posts are all about 4+ years old so I am wondering if anyone has installed a set of these recently, maybe the seal design problems have been corrected since some of these comments were posted.
  2. William623
    Orlando
    1973 ford maverick grabber
    I just installed a set on one of cars and they do certainly take some force to close. My previous seals were in good shape also but I have to say I have noticed a difference in the seals and it was well worth it.
  3. fullcm
    fullcm Doug
    Michigan
    74 maverick
    I wonder if over time they will take a set and the doors will close easier again.
  4. 71gold
    I would think if they close easy they wouldn't seal as well.
    mojo likes this.
  5. William623
    Orlando
    I installed a set on my other car about 5 years ago now and they do get a bit easier but it is never "easy".
  6. Acornridgeman
    Wisconsin
    I have installed 3 of the AK kits so far. Never had issues with installing the seals or problems with closing the doors. I did have issues with the metal clips not fitting very well on the cats whiskers. Needed a bead of the 3M black adhesive to keep those from coming loose.
  7. William623
    Orlando
    I have to ask, what are "cat whiskers"?
  8. fullcm
    fullcm Doug
    Michigan
    74 maverick
    Are the cat whiskers the window frame seals that go down into the side rails?
    That is good to know because I also bought a set of those.
    I am also changing the upper door seal and the beltline seals.
  9. fullcm
    fullcm Doug
    Michigan
    74 maverick
    I think that is the seal that goes around the inside of the side window frame and down the side rails (not the belt line seals).
  10. Acornridgeman
    Wisconsin
    No - I was referring to the beltline - the ones with the metal clips that go on both sides of the glass along the length of the door. In ancient times, we called those cats whiskers or window fuzzies …….. :mg: ………….. cause they were fuzzy.
    The Maverick ones are all rubber. :)
  11. fullcm
    fullcm Doug
    Michigan
    74 maverick
    ok, well still good to know since I will be replacing these too.
  12. William623
    Orlando
    Ah I can see where that came from now. I have replaced the beltlines in a few mavericks and sometimes they do need a bit of help to stay in!
  13. Craig Selvey
    I have installed the lower seals and have had no issues. Yes...the doors are tight at first, but they do get better. The "metal" part of the seal goes to the front of the door and is made to pivot a little when the door shuts...so don't glue that part.
    William623 likes this.
  14. William623
    Orlando
    I made that mistake on my first car. Learned my lesson after that lol.
    Craig Selvey likes this.
  15. fullcm
    fullcm Doug
    Michigan
    74 maverick
    Just installed the lower door seals, I saw lots of posts about them being too tight so I put the ends of the new seals between two pieces of wood and compressed them in a vice to about the same thickness as my old ones. Left them like that overnight and they came out with a nice 'pre-set', after installation I had no problems with them being too tight.
    M.A.V., mojo and Krazy Comet like this.
