door weatherstrip
Discussion in 'General Maverick/Comet' started by OLD GOOSE, Mar 12, 2016.
  1. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    Not that it makes a difference at this point for rotor 22, but I decided to slam the doors shut when it was still setting up so things might move into place where they should be. But, then I took that chance that things could get pushed where they shouldn't be. One door fits perfect after closing and the other is not so good, so maybe I hit 50%. It's all a gamble.
    Craig Selvey likes this.
  2. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    My stepson almost blows my ears out when he slams a door. He's now met his match:biglaugh:
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    Bigger problem might be that you got a pretty good headstart on him when it comes to cumulative hearing damage. So, we all know who's gonna win that match. :1st: Being a car guy for lots of years sure takes its toll on the old eardrums. :beaten:
    I sure hope I can find all this useful info when the time comes to do my weatherstrips too. Doubtful I'll have time to do all this kind of stuff AND actually get it running in the same year too. So, it'll have to just look like hell so long as it runs like crazy. lol
  4. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I am fed up with this door seal. Got it glued in properly and now the bottom half of my door is misaligned with the quarter panel, as if the seal is holding it off:facepalm:
  5. 71Mavrk
    71Mavrk Member
    Nevada
    Same story for me. My doors were perfect until I installed the weather stripping. Driver is still nice but the bottom of the passenger is pushed out and I have to slam the hell out of it. I might rip it out and replace it.
    Micah
  6. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Yup. Same issue on the passenger side. I tore the seal out and door shuts like it used to. Now comes the laborious task of stripping the old adhesive off the door.
    I'm sorry I ever started.
  7. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    If you do, beware of the adhesive. Damn near impossible to get it off. I pulled a piece of it off and it took the paint with it.
  8. 71Mavrk
    71Mavrk Member
    Nevada
  9. groberts101
    groberts101 Member
    Minneapolis, MN
  10. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I'm concerned it will also lift my new paint. I've had the best luck with abrading most of it off with a brass wire brush.
    Was chatting with Craig today and he brought up an interesting point. My door is slightly low right now and that might be reducing the clearance between the bottom of the door and rocker panel. I'm going to raise it a bit tomorrow and see if there is any joy to be had.
    There is a guy on evilbay selling some NOS door seals for $250 plus shipping:yikes: I'm not there yet. Its cheaper to restore a Packard than to buy Maverick parts there these days.
    groberts101 likes this.
  11. groberts101
    groberts101 Member
    Minneapolis, MN
    If your paint is fully cured then you won't have any issues with either product. We used the 3M stuff at the body shop once when.. ahem.. "a guy" put some badging on crooked and they had to be replaced. I was even more stressed out to be doing that on fresh paint but didn't damage the clear-coats gloss even in the least. The goof off stuff I rec'd above is also solvent free and basically just softens and helps reduce the mechanical work needed to get it all off. Sorry to hear about the difficulties and good luck with getting back to square one without any more issues.
    PS. I just thought about 3M having several different adhesive removers years ago and IIRC some were actually solvent based. Doubtful that they make them with the same formula anymore with the tighter VOC laws these days but make sure you get the one Micah posted above that's safe for urethane's and plastics. Too lazy to look right now but you could also check 3M's site directly just to be sure you get the right formula if you do decide to use it.
  12. Craig Selvey
    Paint sticks work well to help raise the door and not mar the finish.
  13. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I got enough of it off to re-apply another seal without fear of too much buildup.
  14. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I still would like a set of NOS seals. I should be receiving a set along with my winning Mega Millions ticket.
  15. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Tried 3M adhesive remover. As others have stated, it rocks:29:
