DOUBLE-JEOPARDY question of da day: The Ford Dash Squeak...
Discussion in 'General Maverick/Comet' started by whisky, Feb 26, 2009.
  1. scooper77515
    So what does a 40 year old perch look like?
  2. rthomas771
    I have 49 year old perches and they don't make any noise. I grease them about every 30,000 miles.
  3. Jamie Miles
    The spring perches are what causes the squeak on my car. I shoot PB Blaster at them every now and then and it quietens them down for a while. Mine are only 2 years old.
  4. whisky
    whisky Whisky
    Vancouver, BC
    72 Comet I-6, 72 Comet V-8
    Now I *think* we're getting somewhere...
    :idea:
    So if I stuff 90% of a 50 year old dead perch into the non-greaseable muffler bearing and charge the flux capacitor until it "wallers out" the loose nut behind the wheel it will stop the paint from squeaking?
    Groovy... maybe I'll try to do that this weekend. :D
    Seriously... thanks guys... now I know WHERE to start hunting.
    Next question to maybe fuel this thread some more and make your brains hurt is why the hell is it ALWAYS the passenger side and not drivers? Mum had 67-68 Cougars, Mustangs, and of course my Comets. Always seems to be the passenger side.
  5. Jamie Miles
    Mine squeaks on both sides. :rolleyes:
  6. rayzorsharp
    I think that about sums it up (y)
  7. 1970mavinator
    1970mavinator Member
    Ruskin, FL
    1970 2dr I6 maverick
    Well if that sums it up...what about the sqeak that I hear near the rear package tray? possibly in the trunk as well, also on the passenger side?
  8. 73rustymav
    73rustymav Member
    clear lake, califorina
    First car in my life 69.5 maverick built 250 inline swap. 73 maverick RIP
    Noooo Jamie don't do that:naughty:. the solvent in the sprays like wd40, pb blaster, liquid wrench and others eat away at the rubber bushings. if u do use anything use lythium grease spray theres nothing in it that ruins bushings. I ruined a complete set of bushings with pb blaster had to buy a complete rebuild kit:mad:. a 2 dollar fix will cost you 200 in the end of it all.:tiphat:
  9. rayzorsharp
    You might want to inspect the panel at the top of the shock absorber. I had a car that I used to run air shocks on and it developed a crack and would squeak like hell while driving. Check it real close around the top shock mounting hole. The weight of the car going up and down would make the cracked metal rub back and forth. It cracked on the same side you are talking about too. I have also heard others on this board describe the same problem.
  10. cjtorinoman
    cjtorinoman Member
    chesapeake va
    My point exactly those perches are not factory none ever came with grease fittings not designed to be greased the are vulcanized rubber in a steel sleeve.
  11. 1970mavinator
    Ruskin, FL
    Thanks Ray, I will look into it!(y)
  12. sierra grabber
    sierra grabber Certifiable
    northern nevada
    CJ, they may or may not have been "designed" from the factory to be lubed. however, my grandfather was a ford mechanic in the late 60 until the 80s and he is the one that told me to take out the little bolts and shove grease in there, also stated that ford instructed the mechanics to lube that spot to stop the squeak. the tech guys apparently came up with screwing in the aftermarket zerks because it saved the mechanics having to keep removing and reinstalling the little bolts. Jamie, i agree with rusty as plastics and rubbers get eaten up and destroyed by penetrants.
  13. justin has a 74
    kentucky
    wow... im lost... does this happen if you turn left lol it happens to me
  14. Jamie Miles
    I don't really care if they get eaten up. I'm going to put a set of roller perches on it sometime soon. I just want them to be quiet for now.
  15. rthomas771
    Ford designed the front end to use grease in the perches. Some bean counter came around late '63 decided to use rubber instead of brass. All 60-62 and most 63 Comet/Falcons had grease fittings perches.
