Doug Thorleys Installed
Discussion in 'Technical' started by shaunh82, Dec 30, 2006.
  1. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    yeah, that's what I was trying to say, I left the reducer on just to illustrate where it ends up, the header clears, but fabbing up a pipe to meet the collector shouldn't be too hard, ugly, but managable
  2. 74merc
    74merc computer nerd
    1974 Comet
    It still sounds like something is funky with your steering. My super comps touched my pitman on a full left turn, just touched. Once they got hot and touched, there was a slight dimple and they don't touch anymore.
    I dunno man, something is out of adjustment or could be someone swapped some parts before you got the car. Tie rod end adjustment can bring the pitman over a good four inches, maybe more, assuming its all out of whack.
    btw, happy new year people, hopefully this one will be better.
  3. chandler
    chandler Member
    Warrenton Mo
    Maverick
    grbmaverickmo,
    If you are implying you may have a set of 6901's for sale drop me a PM I am interested
  4. scooper77515
    Good thread...too bad I have nothing to add. My 6901s fit fine with the power steering setup, and still work well with the manual steering setup.
    I think the pitman arm has been removed and put back on wrong, or something...? :huh:
  5. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    I took the arm off, but could have sworn I put it on correctly, the wheel turns lock to lock, but maybe something is wrong. If it make a difference, I originally had manual steering, converted to p/s, hated it, went back to manual, but kept the p/s box in with the manual arm, the boxes looked identical dimension wise but who knows.
  6. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    theres only so many ways you can put it on and only one way its goin to work:)
  7. Dave B
    I think it's ok, compare yours to the other pic's looks the same.
  8. grbmaverickmo
    Aquashicola, PA
    I think you probally have the arm on right its the headers. As for the 6901`s you might of had a bad set I can personally say I have had 2 of the same header and they fit different.
  9. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    I'm going to fab up a mock exhaust pipe with a bell on it and see if I can make it clear, just need the rain to stop, maybe this weekend I can do it
  10. grbmaverickmo
    Aquashicola, PA
    use 2 inch pipe maybe that will work
  11. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Most of them have a large flat spline, about 1/8" wide, so that it will only fit two ways, right or upside down, and if it were upside down I don't think it would fit the center link....
  12. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    Wow, what can I say, I've been away for awhile. When I built this header the wheels were turned lock to lock and I felt that a good muffler shop could make the bend around the pitman arm. It was not an oversight. I know that I could easily make the bend work around all the componets. Others have brought this matter up and feel the same way. I have a couple of pic's that I took with the wheel straight foward. The pics posted earlier showed the reducer bolted to the header. This piece is supplied so that the muffler shop can cut it to size and weld his bend to it. This header was not designed to have a straight outlet.
  13. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    That pretty much clears it up right there.
    Everybody else was getting worried that they wouldn't work - not me though. ;)
    Good news. Thanks again for your efforts. :thumbs2:
  14. Dave B
    I've spent some time under my car the last few days looking into all this, I also think that any good exhaust shop will be able to make it fit, no problem.
    I should also add these are the nicest headers I've ever owned, the quality is 100%, and I hope this doesn't stop you from doing any other designs in the
    future, this has to be the first "NEW" set of headers designed for a Maverick in almost 20 yrs.and the first set ever designed for a Maverick. You said you could do it, and you did.
    Thanks again for the time you've spent getting these to the market, and I'm going to order another set in the spring.
  15. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    I was just wondering if my car was screwy, these are very nice, , just need a little brain storming, overall, I am very pleased, I'll let you guys know if my cut/weld elbow works, as I don't have many good exhaust shops around here, I know I'm NOT going to midas, they're dumb as bricks up here.
    Thanks Jamie
