Drag link hitting stater
Discussion in 'Technical' started by Aaron.STL, Mar 31, 2015.
  1. Aaron.STL
    Aaron.STL Member
    Point Mugu CA
    1976 Maverick 302
    The gear reduction starter looks great but did not fix the problem. I have been out of town and finally had a chance to look at the car again today. The reason the engine is sitting to low is that the previous owner skipped installing the 302 frame mounts using only the motor mounts.
  2. rthomas771
    Do you have Maverick mounts or Mustang II mounts?
  3. Aaron.STL
    Aaron.STL Member
    Point Mugu CA
    1976 Maverick 302
    I'm not sure which motor mounts are on it. I'm heading to New York for work this week and will be hoping to find the frame mounts at a junkyard. I am probably going to get a new set of motor mounts as well. I figure if I get them from the local parts store and I don't need them it will be an easy return. Cheapest I have found new frame mounts is 110 from http://critesperformanceparts.com
  4. Bryant
    could the centerlink be upside down? in the pic it looks like its curving upward. i dont remember but i think is supposed to curve down from the idler arm.
  5. Krazy Comet
    Dismal Swamp
    The center link is approx level to the point passenger inner tie rod connects, then curve downward to the idler...
  6. mav1970
    If either your idler arm or pitman arm is bend that would arch your center link up as the suspension turns
  7. Aaron.STL
    Aaron.STL Member
    Point Mugu CA
    1976 Maverick 302
    No frame mounts and I can't find any bolts for the engine mounts to the frame.
  8. 71Mavrk
    71Mavrk Member
    Nevada
  9. Paul Masson
    1971 Grabber
    WOW! Look how close that exhaust manifold is to the lower control arm pocket!!! And those holes should have bolts in them, holding on the frame mounts.
    Glad to hear you got your problem figured out. Now, just to get some frame mounts and bolts...
  10. Aaron.STL
    Aaron.STL Member
    Point Mugu CA
    1976 Maverick 302
  11. Krazy Comet
    Dismal Swamp
    The big ole nut between between the motor mount and block is a major clue...
  12. 71Mavrk
    71Mavrk Member
    Nevada
    You might want to look for a belly bar too. I'm assuming that was omitted also.
    Micah
  13. Aaron.STL
    Aaron.STL Member
    Point Mugu CA
    1976 Maverick 302
    There is not a belly bar on the car. All of the info I have read in the 302 swap say that it's optional. Unfortunately the frame mounts are not optional.
  14. 71Mavrk
    71Mavrk Member
    Nevada
    It may be optional in a swap, but I believe that every V8 car got them. It is actually something you would want to do even if you had a 6.
  15. mav1970
    Good to see you found the problem - it had me thinking how the center link was getting "up" into the pan when, in fact, the pan was coming "down" into the center link :slap:
