Draining Fuel
Discussion in 'General Maverick/Comet' started by Elephant, Mar 18, 2020.
  1. Elephant
    Elephant Member
    Katy, TX
    1977 Maverick
    Finally tried starting my 302 up last night after sitting for months and months. Gas is likely bad. What’s the best way to drain the tank (half tank) so I can put a few gallons of fresh in there?
  2. Krazy Comet
    For last 55 years I've used a siphon hose, problem is one small enough to fit in the unleaded opening isn't large enough to drain very quickly.
    How does the fuel smell? IF it isn't rancid, engine should run fine.
    I have a old U-Haul box truck that hasn't had gas added since '13, it still ran last year. No guarantees on today.
  3. TeeEl
    TeeEl Senior Member
    Colorado
    Hotrock, 71gold and Krazy Comet like this.
  4. 71gold
    I always put a drain plug in all my tanks. while you have it out to clean it this would be a good time to install one...:yup:
    Russell likes this.
  5. maverick600
    maverick600 Member
    San Angelo, Texas
    I bought a hand pump from Harbor Freight and used it in mine. Hooked it up to the steel line coming out of drivers side fender. Worked great but is manual so you'll get a workout.
  6. Powerband
    Powerband Member
    NY's \H/
    and what to do with 5-8 gallons of old stinky gas ? ...
    ... usually I mix with fresh for the Ferguson tractor (TO-20) which has @ 6:1 compression .
    TeeEl likes this.
  7. Elephant
    Elephant Member
    Katy, TX
    1977 Maverick
    Well I got it all started up after cleaning the carb and I’ve burned through it all. It’s not THAT old. Good knowledge for future!
