Drilling out axle for 5 lugs
Discussion in 'General Maverick/Comet' started by pachecoj, Mar 23, 2008.
  1. Dave B
    Thanks Jamie! Thats what I figured, so I doubt that you could get the smaller drums in 5 bolt...:hmmm:
  2. JOEXR793
    JOEXR793 Member
    Cleveland Ohio
    I have a 1976 Maverick Stallion, and 85 More Mavericks and Comets in Inventory.
    if its an 8" ya might be able to change out axles and backing plates,, at the worrst case,,, change out the carrier assembly and leave the case still in the car
  3. mean_maverick
    you have to change out the case when going to 5lug. the bearings and the bearing housings in the case are smaller and wont swap out. just pick up a 5 lug rear, swap the whole thing and have better/bigger brakes and 5 lug all at the same time...
  4. mavmike72
    mavmike72 Member
    louisville kentucky
    here is the deal my rear end was 4 lug i drilled out the axels and the drums and i have had no problem with it went to 5 on 4.5.....so any machine shop can do your axels and if you dont wont to drill out the drums you may get new ones if you dont wont to drill drums.....
  5. mean_maverick
    well if u drill the axles then chances are you're going to HAVE to drill out the drums as well because if u just go buy 5 lug drum, they're going to be for the bigger grakes versus the smaller brakes that you would be running.... just my thoughts :huh:
  6. mavmike72
    mavmike72 Member
    louisville kentucky
    probley right thats why i drilled both mine so they would match.....
  7. mean_maverick
    yeah, if a person was to do it then you're way would obviously be the best (y)
  8. mavmike72
    mavmike72 Member
    louisville kentucky
    thanks but the reason i did it is because im cheep but you no that ha ha .........
  9. 71gold
    ...i drilled both of mine so they would match..... then bought a parts car to get the ...front disc. swap stuff...and put the ...5 lug rear end...in also...
    looking back...the drilling to me was not worth all i went through to get it done...JMO
    ...:cool:...
  10. mavmike72
    mavmike72 Member
    louisville kentucky
    but im doing a budget build because im a poor man with a hobby (i no poor and hobby dont go together but what the hell) ha ha ......and buy a parts car im doing good to have one car nevertheless two of them ............
  11. 71gold
    if he brought in his parts...what would your ...machine shop charge to do the work...:huh:
    ...:cool:...
  12. mavmike72
    mavmike72 Member
    louisville kentucky
    to be honest i work in a tool grinding shop for special tooling i dont do the pricing and am not sure what they would charge. I run the machine shop but dont price the stuff but if i were doing this on the side 40.00 for both axels and drums drilling them out...
    of course he would supple new studs to press in.....
  13. 71gold
    ..."on the side $40"...
    ...welding up and finish out...2 axels
    ...welding up and finish out...2 drums
    ...drill 2 axels
    ...drill 2 drums
    ...press in 10 studs
    ...through the shop price...$XXX
    ...plus 10 new studs.........$XXX
    ... 2 new tube seals.........$XXX
    total $ too much
    ...again...JMO
    ...:Handshake...
  14. mavmike72
    mavmike72 Member
    louisville kentucky
    allright.......................:huh:
    you win im done..............
  15. pachecoj
    pachecoj Member
    RI
    1971 Comet
    9" drums for the 4-lug and 10" drums for the 5-lug.
    Jason
