drive shaft question
Discussion in 'Technical' started by maverick7072, Jul 7, 2016.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    I have a chance to buy a maverick driveshaft out of a v-8 mav ,mine is a 6 cylinder originally and was wanting to know if there is any difference between the I-6 and v-8 drive shaft
  2. rthomas771
    Hotrock likes this.
  3. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    mine is a originally 72 grabber that came with a 250 I-6 and the drive shaft forsale is out of a standard 72 maverick that came with a 302-c-4
  4. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    As long as they are both 2 doors it will be ok.
  5. stumanchu
    stumanchu Stuart
    Portland, OR
    Nice chart.
    I had no idea there were so many different lengths of drive line. I got one from a junkyard from a 73 2dr 250 and put it in a 74 2dr 302.....both c4....and I think it will work but havent drove it yet.
  6. 71gold
    you need to know if it will work before you drive it...:yup:
  7. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    If you have a v8 & a c4 I`m pretty sure it will be 45 & 1/2 inches for a 2 door.
  8. stumanchu
    stumanchu Stuart
    Portland, OR
    You make a good point.
    According to that fine chart, it will work. BUT, before I try to smoke tires, I will go slow. Will also measure shaft and look at the chart again.....just to satisfy the carpenter voice in the back of my head that says "measure twice, cut once."
  9. 71gold
    with me...I set it on the ground and make sure it's not ...too long, you can live with a little short.
    I slide the yoke all the way in and mark it. then when it's installed and on the ground I look to see where the mark is...I like at least 1" out...JMO
