Drive shaft yoke comming up short
Discussion in 'Technical' started by Racer_X, Nov 1, 2011.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    Even better:thumbs2:, I'll look for some when i get paid :D
  2. rthomas771
    A Daytona yoke won't fit a 8"
  3. baddad457
    Where did I mention anything about a Daytona pinion yoke ?
  4. rthomas771
    Where can you get a longer yoke to fit a 8" ? I can have a new driveshaft made for $125 using the old tube ends. Changing a pinion yoke will cost close to the same after its all said and done, not counting the trouble and time. Repacing a shaft is a 10 minute job. How long will it take to change a pinion flange, crush sleeve and oil seal?
  5. Racer_X
    North Carolina
    I'll just put the correct frame mounts on it, that should solve the problem.
  6. baddad457
    Not sure if or where you can get one, All I was saying was there's long and short yokes for the 9's. I fgured the 8's may have had these too and that could be a possibility in fixing his problem. Didn't have to be a new yoke either. There's often more than one solution to any problem. And you don't have to do anything other than swap the pinion yoke in this, I've done it many times, no new seal needed (unless you want to put a new one in) or crush sleeve, the sleeve is in there behind the front bearing anyway and as long as you don't over tighten the pinion nut, there's no change there anyway.
