Dropped her off for the V8 upgrade!
Discussion in 'General Maverick/Comet' started by mashori, Dec 16, 2008.
  1. blugene
    blugene Senior member
    If I remember right I think it is bad on the other side... he'll let us know.
  2. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    Don't the 200 CI six cars in addition to 4 lug wheels have smaller drums than the 5 lug V-8 cars? My 72 302 has the factory drums and I really started noticing how inadiquate they are since I souped the motor up. Perfectly fine in normal driving but sudden bursts of speed tend to require sudden aplications of the brakes.:D Inadiquate brakes were a standard feature for almost all American economy cars from that era at no extra cost! :dance:
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I'll definitely address the breaks after the engine is upgraded. I think I'll do it myself so I can save some money. Doesn't look hard, we'll see.
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Updates!!
    V8 installed.
    He's waiting for the A/C bracket.
    Headers are installed.
    After engine done he's gonna send it for dual exhaust install.
    Maybe it'll be ready by 1/2/09 . . .
  5. Dan Pearce
    Dan Pearce Member
    SC
    It sounds like you're doing everything the right way. I did a V8 swap on my '72. I did everything myself. It's got 5 lug power disc brakes from a '77 4dr car. You're gonna have to change the WHOLE rearend when you upgrade to 5 lug. The backing plates have different bolt patterns. Also, the driveshaft is 1" shorter in the 6cyl car thatn the V8 car. It'll work, but you may have a 45mph+ vibration. You won't need a high stall convertor if you have a stock cam. Etc, etc, etc. Good luck! :tiphat:
  6. Jamie Miles
    Alto, GA
    I've had a few
    Drive shafts are the same between I6 and V8.
  7. Dan Pearce
    Dan Pearce Member
    SC
    I had a driveline vibration that I couldn't figure out. After I replaced the u-joints 2 or 3 times I grabbed the driveshaft out of my V8 Grabber. When I layed them side by side, the OE V8 driveshaft was about 1" longer than the 6cyl shaft out of my car. After I put the Grabber driveshaft in the car (didn't even change the u-joints), the vibration went away. The transmission sits farther back in the tunnel with a 6cyl.
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Yea I've gotta look into a rear end. I read some threads but don't know much about the ass of my car (well, don't know much about the nose either) so I'm gonna have to do some searching still.
    Running cost:
    tranny crossmember --------$75
    bell housing-----------------$50
    labor-----------------------$900
    V8 engine------------------$600
    frame mounts---------------$85
    engine crossmember---------$50
    accelerator cable-----------$25
    misc parts-----------------$500
    exhaust-------------------$400
    S&H for parts---------------$50
    total $2,735
    yikes!!
  9. Dan Pearce
    Dan Pearce Member
    SC
    Mine sounds just like yours. 200, C4, A/C. Mine had a 3.00 gear in it. Most Mavericks seem to come with 2.79s. That 3.00 is a good gear! It works great with a 25-26" tire. I reused the 3rd member when I changed the housing & axles. Later on I built another 8" w/ 3.55s & a locker & swapped it out. But man, for cruising & long burnouts the 3.00 was key. Not to mention I dropped 2 mpg when I moved up to the 3.55!
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    what 8" did you use? is it easy to swap the rear end?
  11. Jamie Miles
    Alto, GA
    I've had a few
    That is strange. I have a couple of V8 drive shafts, and several 6 cylinder shafts. All of mine are the same. I've also done the V8 swap in a couple of cars, and had no issue with the drive shafts.
    A 5 lug from any '71+ Maverick or Comet will bolt right in. Only real difference is they changed the diameter of the center "hub" piece that fits through the center of the wheel. It got bigger in '74. Won't be a problem unless you try to use factory 5 lug '71-'73 wheels on a '74+ rear. Any aftermarket wheels will fit either rear with no problem.
    Swapping the rear is straight forward. Getting the emergency brake cables loose was the only part that really gave me any trouble.
  12. Dan Pearce
    Dan Pearce Member
    SC
    Your car should have an 8" in it now. My rearend came from a '77 4dr V8 car. What kind of exhaust are you gonna run?
  13. Dan Pearce
    Dan Pearce Member
    SC
    Mine might just be a bastard, but that's how was.
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    If I have an 8" in there already then should I still change it?
    For the exhaust I'm gonna have a dual with dumps at the axle.
  15. Jamie Miles
    Alto, GA
    I've had a few
    You have to change the rear, because the one you currently have is 4 lug. When you put disc brakes on the front of the car, they will be 5 lug. You cannot swap 5 lug axles into a 4 lug housing, because the bearings are different sizes, and the axels themselves are a different diameter, so you can't just swap the bearings. You must swap the entire rearend. You can swap the center sections between 4 lug and 5 lug.
