Drum brake backing plates
Discussion in 'General Maverick/Comet' started by Renton5, Jan 15, 2021.
  1. Renton5
    Renton5 Member
    Van Nuys, CA
    1971 Maverick, 200 engine, 2dr
    Hello, my Maverick and Comet Cousins!
    I have a ‘71 Mav, 200 engine. I’m doing a full brake job. Starting with the front right, I see deep grooves in the backing plate’s shoe riser—or whatever it’s called. I’m sure the other three plates are in the same condition after 50 years! Does anyone know where I can get replacement backing plates?
    Thank you!
    Everyone be careful out there and stay well!
  2. mojo
    If finances will allow this might be the time to consider a disk upgrade. Just a thought!
    rickyracer likes this.
  3. Renton5
    Renton5 Member
    Van Nuys, CA
    Hi!
    I thought about that, but...yes, finances won't allow
    it at this time. I've also been thinking of putting in
    three small carbs, to equalize fuel distribution in the
    engine, but that will have to wait also!
    Bye,
    Daniel
  4. Krazy Comet
    Dismal Swamp
    Stopping is more important than acceleration. I'm yet to see a mild 6cyl that's happy with multiple carberation. Possibly with progressive linkage setup, but 99% of time you're still running on center carb.
    If you're not going upgrade to discs, I'd look at possibly having a machine shop weld the area and cut it to correct height.
    With good welding skills could fix it yourself and file it.
    rickyracer and mojo like this.
  5. mojo
    Putting multiple carbs on stock engine will do nothing for performance n will cause grief trying to get it setup properly if you don’t know what ur doing.
    Ronald Hopkins and Craig Selvey like this.
  6. Hotrock
    Munroe Falls, Ohio
    It's not the years that wear the backing plates but rather the miles.
    If money is an issue; I would inspect the other three backing plates for wear before attempting to purchase all four. Also upon replacing the brake shoes a dab of grease on each backing plate pad will prevent this type of wear in the future. It goes without saying; keep the grease off the new shoes.
    I would suggest searching for used backing plates.
    Member Craig Selvey is a possible source:
    Craig@MaverickCorral.com
    BBMS18 likes this.
  7. Craig Selvey
    Yes, I think I have the backing plates. Email me (see below) if I can help.
    BBMS18 likes this.
  8. Wimavstang
    Wimavstang Member
    Eau claire wi
    73 maverick 2 door ldo
    I just did a disc conversion on mine and I have my old front drums sitting around the garage if you would like them contact me mavstang1973@gmail.com
  9. 71gold
    :Welcome:...:Handshake:
  10. Wimavstang
    Wimavstang Member
    Eau claire wi
    Thank for that 71gold
