Duck tape mav's OTHER ride.
Discussion in 'Other Automotive Tech & Talk' started by Duck Tape Mav., Feb 6, 2009.
  1. Duck Tape Mav.
    Vilonia, Arkansas
    dang it. wish ida known that about three years ago. now I still got a fender on the driver side. some of the bolts are impossible to get to it seems. I'll post examples later
  2. Bryant
    thats a cool project. a huge one to get on the street in just a few months. i would suggest geting a know good motor and trans out of someting else and just put them in the waggon. just rebuild the exsiting brakes. then all you need to do is fix up the body and interior. i would just get some bench seat out of the junk yard, some carpet, either from the auto parts store (they sell rolls of it) or a carpet store. pull out the old carpet and seats, save the seats for restoreatio later, thow away the old carpet. start cleaning the interior, spray paint it all back to some fresh colors. throw the new carpet in put the new bench in and it should be good on the interior. the outside body work will be the bigest challange. i dont have any sugestions on that. good luck and keep us updated with progress reports and pics.
  3. Mavaholic
    You can leave the hood attached to the clip but I had to remove mine by myself and removing the hood made it just a little bit lighter.
  4. Craig Selvey
    Wow.....Dennis has ran out of storage and is now putting parts on the roof!!! Why hadn't I ever thought of that!!! :D
  5. Jamie Miles
    Alto, GA
    I've had a few
    Wow, you think the home owners association would mind if I stored some of my Mavericks like that!? :rofl2:
  6. Duck Tape Mav.
    Vilonia, Arkansas
    either that or santa couldn't fit it down the chimney. The body work's not so bad except for the front and the rear gate. The floorboards are gone. I put my toolbox behind the front seat and its on the ground. literally. I got the doors off and the front seat out yesterday, and today I was sick, so it moved real slow so I only got the outer drivers side fender off today along with the grille and the filler panel that goes between the bumper and the grille. I wanna put it on some concrete so I can pull the motor out and put a new one in. The frame is better than I thought, so I reckon I'll just put the motor mounts in rather than swap clips. As for the carpet, unfortunately it was vinyl or something and it was ratted out. I'll just get some sturdy cheap replacement carpet till I can do the resto. I got one door panel off with the outer skin in fair shape. It's cracked and got some holes in it, but it should be good enough to make a copy outta something else.
  7. Duck Tape Mav.
    Vilonia, Arkansas
    well, yesterday the rain prevented any progress, and today was so wet and muddy. to make it worse, before i got started i stepped in a posthole I had dug next to the wagon when I wanted to raise the body and switch the whole frame. so soaked up to my knees, progress was slow, and I only got the other inner fender off and took some bolts off the dash trying to loosen it up so i can remove it later. The entire front end is dismantled, the motor mounts are undone. and I undid one of the bolts on the transmission holding the drive shaft on through the hole where the floor used to be. after I get the other three the motor should be ready to come out, but living in a swamp, it won't be dry till summer and can't relocate it without getting stuck. Man this stinks. I wish we'da put it on concrete.
  8. Dave B
    HOLY $HIT!! That's an awesome project!!
  9. Duck Tape Mav.
    Vilonia, Arkansas
    thanks. wish it was as easy to fix as it is awesome, but then again, it wouldn't be fun, so I can't complain. Too bad there's not enough business around here to do it for a living. I like the old stuff, but I figure I'll earn a living working on the new stuff. (then grafting some of the better ideas into my old ones, since I'll be training in it anyways.) But for now, it's what I can put into it. And a very long list of need-to-do's. I should post it and use that for status reports... :idea:
  10. Duck Tape Mav.
    Vilonia, Arkansas
    ok, what still needs to be done...
    1. remove the hemi and transmission
    2. put in a new motor and trans. (350)
    3. brakes
    4. patch panel for cowl/door jamb
    5. driver side rear quarter patch panel
    6. front right fender patch panel
    7. rust repair around passenger side cowl/windshield/door jamb corner
    8. make floor pans
    9. new cross-braces for seat to bolt to
    10. new front seat
    11. re-upholster back seat.
    12. headliner
    13. carpet
    14. cargo area flooring
    15. get rear hatch to open
    16 patch the hatch
    17. paint
    18. chrome
    19. passenger door needs to be un-caved in
    20. paint
    21. glass (1 door window, 1 side sliding window, back glass
    22. get the sliding windows to slide
    23. wiring
    24. gas tank
    25. fuel lines
    26. new core support/radiator.
    27. exhaust
    28. wiper motor
    29. lights. brake, headlights, blinkers, dome lights, parking lights, lenses, etc, etc.
    30. scream. cause I'll think im done. then find something else that needs to be done.
  11. Duck Tape Mav.
    Vilonia, Arkansas
    yea its not in order...
  12. Bob Wiken
    Fayetteville, Arkansas
    That is a huge project. Later in the spring I may be able to get down to see it and maybe give you a hand.
    That's the car you should bring to Joplin
  13. Duck Tape Mav.
    Vilonia, Arkansas
    yea it's huge. I'd love to take it to as many car shows as possible. You don't see enough of these things around. So if it's ready i'll take it to Joplin, Pettit Jean, Toad Suck, and any other car show I can get in to.
  14. Duck Tape Mav.
    Vilonia, Arkansas
    well, just went out on a limb and tried for more inspiration. I asked Sarah to the prom, and she's gonna give me her answer after church. obviously, a date gives me someone to impress, so the wagon's gotta be done. HOPEFULLY, I'll get the inspiration im lookin for in a couple hours. Then I'll be runnin out there stickin a drop light in there and workin till the parents start yelling at me... I need a lift... like at auto body.
  15. Duck Tape Mav.
    Vilonia, Arkansas
    ok, pic update. didn't get anything done cause i was babysittin, but got some pics of my current status on the wagon. I'll get to work resizing and posting them.
