Dyno! 2,260hp 2,240tq!!!
Discussion in 'Drag Racing' started by maverick75, May 30, 2007.
  1. maverick75
  2. maverick75
    jacks
    *w/open headers and .624/.624 lift
  3. maverick75
    Cool...i wanted to go to UTI but i decided to go to a Fabrication school thats closer.
  4. maverick75
    I'm going to do a sim on a stock engine and compare them to what the manufacturers estimates.
  5. maverick75
    Heres the sim on a 97 mustang cobra
    SAE net 305Hp@5800RPM 300Tq@4800
    Sim est 309Hp@6000RPM 304Tq@4500
  6. scooper77515
    Close enough for me...
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I haven't read anything on it to be fair, but I have always worked under the notion that headers provide 20-30 FWHP on a stock to mild engine.
    Much more as you go from mild to wild.
    Like I said though, if I have seen any estimates from knowledgable sites online, I didn't pay any mind. Just would have been surplus info in my thinking.
    Now, I don't know that my idea of header increase is correct, I just heard it from the really old-schoolers, way before the net, and took their word.
    On my engine modeling program, it is dead on what I was told.
    On computer dynos, they make MINIMUM of 20 HP on any dead stock V8, and that is often before adding a 4v. Then every mod beyond that magnifies the HP offered by the headers. (or the headers magnify the HP offered by further mods, however you want to look at it)
    In fairness:
    I never have modeled an engine that was stock and single exhaust, and then put headers on without changing to dual exhaust that instant.
    It wouldn't make sense to add headers and keep the stock muffler and single exhaust pipe. So in some instances, I am sure the move from single to dual exhaust, while simultaniously adding headers, inflated the gains on some level.
    And:
    Although I have modeled engines with 2v carb and headers (dual exhaust), this is not an optimum model. Most folks would run with headers and a 2v carb for a very short period, if at all. Improving intake breathing and exhaust breathing kinda go hand in hand. Not doing both defeats the purpose.
    So I believe that between headers, duals, and 4v intake/carb, none mean nearly as much without the others.
    Getting off topic now... sorry.
  8. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Well ... we'll see how she runs ... I am leaving my dual exhaust and H-Pipe setup on the car ... just gonna run a pipe from the stock manifolds to the H-pipe ...
  9. ratio411
    ratio411 Member
    Pensacola
    I predict it will be quieter, run about 5* warmer on average, and you should notice less butt-meter power.
    In theory, it should lose a small amount of economy as well.
  10. ratio411
    ratio411 Member
    Pensacola
    Just for giggles, here is what I get for a stock 72 302.
    2v and single exhaust...
  11. maverick75
    i was going to do the same thing heres what i got
    *UPDATED
  12. dmhines
    Cumming, GA
    The results you guys got are quite different ...
  13. maverick75
    i think thats my fault i mixed up some of the numbers let me update it.
  14. jmgford
    jmgford Member
    Iowa
    Thanks! Man, if it truly does have that kind of power, it should be a handful!
  15. maverick75
    i ran my sim on the 72stock302 with
    1.781/1.460 valves
    cam specs 368/381(valve lift) duration 270/248
    300CFM 2bbl(what did the stock one come with?)
    dual exhaust w/stock manifold/mufflers(my sim doesn't have single exhaust)
