Dyno run.....
Discussion in 'General Maverick/Comet' started by Earl Branham, Jan 28, 2009.
  1. rthomas771
    Earl, Here's the pic I took after 4 pulls showing 219.71hp/260.44 torque.
  2. Earl Branham
    Lugoff, SC
    Jeff; thanks for the pic! The page I got was 217.06. I like yours better!!:)
    Got to go to the carwash and clean the back of the engine today, so I can track down that damn oil leak! Hope it is something simple, like the intake. And, it is a bit chilly today!!!!:hmmm:
    Later,
    Earl
  3. mavron 70
    mavron 70 Member
    R.I.
    1970 maverick 5.0 t 5 trans 59 ford rear with 4.11 cogs
    hey earl, are those stock 86 pistons without the flycuts? my engine is an 86 h.o. with the stock pistons and 86 heads, and an e 303. I was told if i changed heads the pistons would kiss the valves, for lack of flycuts. I wonder if i could get away with e 7 heads on my ride?
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Hope you can get some track numbers on the car soon. Pretty awesome though!
  5. 71gold
    Earls pistons...:tiphat:
  6. stockhatch
    stockhatch Re Member
    Boiling Spring Lakes NC
    '72 Grabber
    Doubtful. Most people running 86 flat tops wont clear with a stock cam and E7s much less the E303. Fix it for good with a set of Twisted Wedge heads. Should clear easily, even with the cam if you run those heads. :D
  7. Earl Branham
    Lugoff, SC
    Well, my cam is a B303, and '90 E7 heads, and it runs fine....no interference.
  8. mavron 70
    mavron 70 Member
    R.I.
    thank's for the replies boys :cheers2:
  9. courier11sec
    courier11sec Member
    Tucson, AZ
    Nice work Earl.
    Seems like you could fatten it up just a touch at WOT.
    Great flat torque curve. Bet it drives nice!
    On the vibration, how's the driveshaft?
  10. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Well there's your problem. I wouldn't be surprised if you gained quite a bit of power - once you put all the parts on. :tiphat:
  11. rthomas771
    Earl's Mav didn't vibrate on the Dyno. The only thing that was not turning were the front wheels
  12. mean_maverick
    wish there was a dyno around here.... :rolleyes:
  13. Earl Branham
    Lugoff, SC
    Seems like the vibration is in the front end somewhere. Frank and I put on a set of RotorPros rotors a few years back, and he had problems with the bearing race in one of his. I'm going to check mine out this weekend, when it warms up a touch. As for fattening up the top end, I think I'll do that when I get it to a track and see how it runs on the wheels. Dyno guy (Scott) said I could go up two or four jet sizes (secondaries) , and might get a little bit out of that. Be interesting to see. Thanks,
    BTW, I think the driveshaft is ok, since it didn't vibrate on the dyno. But if it keeps up, I'll have it checked!
  14. 71gold
    did you click your heels when you made this wish...
    ...:D...
