Dyno Sheet..its a heartbreaker
Discussion in 'General Maverick/Comet' started by LoxMan71, Jan 6, 2004.
  1. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Well to start I've seen cams much worst then that one, and it's wasn't all that bad. If you were to stop at a light the guy in the honda next to you would think twice about messing with you so it does have a lope to it.
    Call kris at Comp Cams 1-800-999-0853 he is one of the best in the business and can tell you everything you need to know, he can even tell you what stall and gear ratio would be good to use.
    Make sure you ask for him!
    This cam is kinda pricey Summit as it for about 250.00 and I've never seen it on ebay.
    If this isn't a daily driver you won't have a problem at all, if you plan on using it every day you'll need to tinker with it from time to time but that's why we play with these toys.
    Back to the original post, with out a stall of 2800 or greater I'm not so sure about the DP, all that fuel without being able to rev might stall the motor.
    Total timing of 32 to 36 is a good place to start and then play with it from there.
    Change ONE thing at a time that way you know if what you did helped or hurt you.
    As alway just my 02
    Bossmav
  2. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    sound file of a Comp cam they say its a custom grind 302 bucks with ship
    my 393 AFR 185s Full CnC ported 11.2-1 com
    2 1/2 exh With H pipe all the out the back flowmaster mufflers
    110 center int Dur @0.050 246
    int lift 576
    exh Dur @0.050 248
    exh lift 600
    idles around 875-1000 rpm
    http://home.columbus.rr.com/maverickgrabber/maverick(1).wma
  3. n2omaverick
    n2omaverick Member
    Delaware
    Cam
    Damn Chris at comp cams designed my cam and its quite a bit bigger than that, and mine is on a 112 lc which takes away upstairs but runner velocity is higher at lower rpms, I am giving up 85 Ci but my heads are equil, I hope when I finally get mine on a dyno, it pulls to 7000 because that is where I go through the traps at anyway,
    Dave
  4. MaverickGrabber
    Cardington, ohio
    have not put mine on the dyno yet but i shitf at 6800 and its still pulling ..but dont want to push much more on with Hyd Rollers
  5. n2omaverick
    n2omaverick Member
    Delaware
    HYD ROLLERS
    There is a simple solution for that, I am a advocate of big spring pressure! the more the better! I had a 90 5.0 and went through the traps in the 7000 range with a hyd roller and a motorsport rpm extender!
  6. MaverickGrabber
    Cardington, ohio
    the Heads was set up for what i am running could go up to 680 lift the valves and springs when i orderd the heads was redone By AFR under cut stems cost alot more then the $1399.00 but its worth it to handle the Rpm with Hyd roller
  7. n2omaverick
    n2omaverick Member
    Delaware
    set up
    Just dont confuse a springs ability to take high lift, with its spring pressure rating, the two facts couldnt be farther appart
    Sounds like you have what you need.
