Easiest detachable exhaust methods?
Discussion in 'General Maverick/Comet' started by scooper77515, Feb 23, 2014.
  1. scooper77515
    I have never done it with a mig, but used to weld stainless to cast iron back when I worked in machine shop. Never to a thin pipe, though. We will see.
    I live near Houston and in a very oil- and industry-heavy area. I have gone to several pipe and industrial supply stores and none of them carry the v-band clamps. Looks like I need to make an order to summit soon.
  2. Dave@RACEWARE
    Dave@RACEWARE Member
    New Britain, PA
    73 Maverick Graber 72 Comet GT
    Not much different then welding steel to steel.
  3. bmcdaniel
    Not quite. If you use the wrong wire or rod the stainless can crack and it can change the stainless around the weld so that it isn't really corrosion resistant anymore.
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    lol.. no doubt! Especially with flux core setups.
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    yep.. and the welds will sink into the pipe too.
  6. bmcdaniel
    To mig weld stainless you need special stainless wire, the number depends on what alloy of stainless you want to weld. And it takes a special gas mix that isn't as inert as you would use for carbon steel.
  7. scooper77515
    So what wire and what gas would I need for 304 stainless on a steel pipe?
  8. bmcdaniel
    308 or 309 wire with tri-mix shielding gas, like 90%He/7.5%Ar/2.5%CO2.
