Easy nine inch ford!!!!
Discussion in 'Parts Interchange' started by rsillmon, Jan 19, 2009.
  1. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    My car has a 57-59 "big bearing" axle in it...with a few upgrades.
  2. Jamie Miles
    Alto, GA
    I've had a few
    Such a car did not exist from the factory. There were no '69.5 Grabbers. The only rear the '69.5 came with was the 7.25 rear.
    I've got a '68 Mustang 9 inch with a 4.11 gear that was under a '69.5 with a 170 in it. It was a hilariously slow car.
  3. Jamie Miles
    Alto, GA
    I've had a few
    What would be a good price on a '57 Ranchero 9 inch? I know where I can get one. No telling what gear or differential is in it since it was an old drag racer.
  4. JHodges
    JHodges thumper
    Dora Alabama
    I know where I can get a 59 wagon that is preey much complete for $200 but it has been setting on the ground for probaly 20 years. It has a large tree about 2 feet in diameter on each end. Only way I have figured how to get it out is to winch it onto its side. I may go get it one day but I doubt it
  5. Duck Tape Mav.
    Vilonia, Arkansas
    do it. the 50s wagons are awesome. mine sat for 30 years and i still plan to fix her. I heard from my auto body teacher it should have a ford 9 inch rear, but who knows what they changed. I can always hope.
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    57-up will have the 9".
    57-59 will have the narrow 9".
    60 T-Birds supposedly have a good 9" as well, but I don't know if that means the 60 Ford has a narrow 9" as well.:huh:
    57-59 Ford, Wagon, or Ranchero... and you are okay.
  7. JHodges
    JHodges thumper
    Dora Alabama
    that would be cool but this one is way to far gone. It sat on the ground for years and kids busted out all the windows. I had basically thought of getting it to take out the 9 inch but I'm not sure I wanna do all that work
  8. ratio411
    ratio411 Member
    Pensacola
    Get a junk 9" and cut the center out and have your tube ends welded to it.
    Costs about 200 bux (around here), and when you use your tubes, it comes out stock length. Stock length then allows you to use the stock axles, and the stock tubes leave you the stock brakes. So all you need is a 28 spline chunk, a welding shop, and a junk 9" housing to swipe the center from. Easy 9" that is totally 'stock'.
  9. gasjunkie
    gasjunkie Member
    uniontown, pa
    1972 maverick
    sorry to bring up an old thread but do you need any certain 9" housing like and early pre 67? or a later one?from a car or truck? from what i understand the 8" axle tubes are smaller but fit inside the 9 inch instead of butting against it. or maybe i'm misunderstanding.
  10. mr wackodog
    mr wackodog Member
    lewiston idaho
    1972 mav
    just a thougt i had a 67 coug XR7 that had a 289 2brl c4 and a 28 splin 9 inch and yes it came that way right off the lot was not a spl order car. i wrecked it now the rear is in my 68 must had to chang the geas thoug they wer 2.79 did not work very well with 4 speed
  11. carshowreject
    carshowreject Member
    Penciltukky
    1978 Bronco, 1994 Thunderbird ( the 77 Maverick is hers)
    what about a 9 out of an early bronco.... i know the bolt patern is diferent 5 on 5 1/2 but new axls can take care of that.... ill measure one tomarrow and see how close it is..........
  12. baddad457
    You will also need to relocate the spring pads on a Bronco 9. They have the springs on top and a different spacing.
