Easy T5 swap use full mustang trans , keep mechanical clutch , no parts to buy !!
Discussion in 'Technical' started by towrecker, Aug 26, 2015.
  1. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    I just caught this in you post, you can install the T5 and use your bellhousing, clutch/flywheel and Z linkage by purchasing a adapter plate like this.
    https://www.summitracing.com/parts/...0lFHJEy18ZEvMQCJWXzIDxy_TRbsBvMBoCDvMQAvD_BwE
    Scott Drake also makes a T5 clutch fork conversion fulcrum so you can use the T5 bellhousing and your clutch/flywheel and Z linkage.
    https://www.summitracing.com/parts/...mDx6TROAMBPiNco8oWML7bwPc19DxJPxoCOOkQAvD_BwE
    But first we need to figure out what’s up with you input shaft,
  2. BBMS18
    BBMS18 Member
    75 Comet
    That seems odd, it’s definitely cut. Let’s go about this another way remove the shift cover and count the teeth on the input shaft.
  3. Krazy Comet
    Dismal Swamp
    Agreed, I've never seen any T5 that input shaft bearing surface was as short. Apparently cut.
    My confusion was because it closely resembles a big block toploader input.
    You should confirm it's internal condition.. I busted the cluster in my '86 5.0 Stang T5, (ID 169) when I short shifted 2nd to 3rd. The 199 is touted as having a stronger gear set than earlier transmissions.
  4. BBMS18
    BBMS18 Member
    75 Comet
    Also check the diameter of the input shaft pilot bearing surface 0.668 or 0.590?
    If you don’t have a micrometer will a 5/8 wrench fit on it?
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Definitely been cut.
    In my Mav.
    Maverick 1973-Pure Muscle.
    :scratchchin: Dont known where is it.
    I open the T5 only to clen it. Really dont known how to repair it. It was dirty but looks ok.
    33.jpeg Here .667in its ok?
    7.jpeg 10 teeth
    34.jpeg Here 28
    37.jpeg here 23 teeth
    Inside looks ok. Only this looks cracked(used), I open only to clean, Really dont known how to repair it. I wanna put in my car.
    What do you think? Its ok?. If i need to change the input shaft dont known how to do it. I dont wanna spend more money, the cheapest solution is that i want.
    And thanks for help:cool:
    BBMS18 likes this.
  7. BBMS18
    BBMS18 Member
    75 Comet
    “ View attachment 123956 Here .667in its ok?”
    This is the correct diameter for V8 input.
    “ View attachment 123959 here 23 teeth”
    This is a common gear ratio for V8 trans.
    “Inside looks ok. Only this looks cracked(used), I open only to clean, Really dont known how to repair it. I wanna put in my car.
    View attachment 123960 View attachment 123961 ”
    Yes, that is used but not the end of the world & should be ok to run.
    “What do you think? Its ok?. If i need to change the input shaft dont known how to do it. I dont wanna spend more money, the cheapest solution is that i want.”
    The bad news is whoever sold you the trans screwed you and you will have to change the input. But a input is not to expensive if you can manage it yourself.
    Check out YouTube for some T5 repair videos.
    “And thanks for help:cool:”
    You’re welcome
    Here’s a link for a input, if you look around you may find one cheeper.
    https://www.summitracing.com/parts/...99VgeXNCTRujZblKe3BtH6CPgEVuxJvBoCh54QAvD_BwE
    Where are you located? there maybe a member close by that can help you with installing the new input, or recommend a shop.
    464925 likes this.
  8. BBMS18
    BBMS18 Member
    75 Comet
    Here’s a good video, you are already halfway there.
    464925 likes this.
  9. Krazy Comet
    Dismal Swamp
    464925 likes this.
  10. dyent
    dyent Member
    vancouver bc
    464925 likes this.
  11. Powerband
    Powerband Member
    NY's \H/
    If still has tag you can determine genre or 'count gear teeth' literally for replacement, looks like usable core for rebuild. Most @ 85-93 T5's are similar except for gear count but 'Cobra - Z Rated' have 'pocket cone bearing' instead of roller bearing joining Inp/Outp shaft.
    have fun
    464925 likes this.
  12. BBMS18
    BBMS18 Member
    75 Comet
    Seeing that someone has cut the nose off the input (and who knows what else) I would not rely solely on the tag information of a 29 year old transmission for identification.
    464925 and mojo like this.
  13. Krazy Comet
    Dismal Swamp
    If one is a archaeologist they'll look at witness marks on said tag bolt hole, top cover etc. IF there is only one set of marks it can be fairly safe to assume transmission has never been disassembled.
    464925 and BBMS18 like this.
  14. BBMS18
    BBMS18 Member
    75 Comet
    You are correct, but I don’t have my hands on the trans and even if I did I assume nothing and trust no one.
    464925 likes this.
  15. 464925
    In my Mav.
    Thank you all :).
    I am really grateful for your help.
    That summit racing part is cheap.
    I gonna change the input shaft. So I need save a little money. :rolleyes:
    And doing by my self.
    :thumbs2:
    Krazy Comet and BBMS18 like this.
