E'brock performer Intake
Discussion in 'Technical' started by newtoford, Apr 21, 2008.
  1. Halebopp
    Halebopp Member
    Ankeny Iowa
    CAn you clarify when you say open plenum what is the plenum
    Can anyone post picts of each type?
  2. 48fordnut
    48fordnut Member
    mid ga
    The original torquer with the twisted carb is a great race intake. I made 496 hp with a set of 289 heads and that intake .with the cam I had it would go forever, 8k is where I shifted 7400 thru the eyes. I would use a rpm with a 600 holley. no d/p. small carb gives you port velocity.
  3. bowstick
    bowstick Member
    baton rouge
    1972 maverick 302
  4. newtoford
    newtoford Member
    New Castle Delaware
    so you think that might be a good one for my motor?
    me and bow were already in talks actually:rolleyes:
  5. blugene
    blugene Senior member
    LOL! Those mopars don't play around...:rolleyes:
  6. Halebopp
    Halebopp Member
    Ankeny Iowa
  7. bowstick
    bowstick Member
    baton rouge
    1972 maverick 302
    no problemo .....
    this is one heck of an active thread!!!
  8. Halebopp
    Halebopp Member
    Ankeny Iowa
    I think we have several swaps happening, and I for one fly pretty blind if you guys get a chance read my last few posts on the Marquis motor swap thread I have several questions there.
  9. newtoford
    newtoford Member
    New Castle Delaware
    yup. spring is in the air. that warm breez comming in really gets ya motivated. i know it does me.
  10. Halebopp
    Halebopp Member
    Ankeny Iowa
    Ditto Man Ditto, got 2 5.0's sittiin on my garage floor ( only until I get the hoist)
    Tryign to decide what to do and to which motor,
  11. newtoford
    newtoford Member
    New Castle Delaware
    yea. im just trying to make sure i put my $ to the right parts, maybe find some deals along the way
  12. scooper77515
    Did we cover the torker vs torker II issue?
    Torker289 is no longer made (the one we are talking about here, with the 10 degree twist on the carb). The torker II was Edelbrock's next version, it was lower, had more arch to the runners, and was made to generally give you better hood clearance, from what I have gathered.
    The torker289 is a popular intake still today, and they are getting more and more rare.
    The torker 289 is quite tall. This makes the runners almost straight. You can look in from the top and "almost" see straight into the intake ports on the heads. On Bowstick's ported torker289, I think you actually CAN see into the heads.
    I always intended to run the non-ported one I have now, and get some track numbers, then install the ported one and compare them, but Bowstick was looking for one and I had two so I sold him the one I had been using before I cratered my old engine.
    The torker289 will make the carb sit a bit higher, so you may need to experiment with some different air cleaners so your hood doesn't hit...
  13. newtoford
    newtoford Member
    New Castle Delaware
    well i do have a giant hole already cut under my scoop so hope fully that will make life easier :D
    thanks for the info though
  14. Halebopp
    Halebopp Member
    Ankeny Iowa
    Very stupid and basic question guys what size bolts do I need to mount the motor to my stand? Do they thread into the block ?
  15. Halebopp
    Halebopp Member
    Ankeny Iowa
    yeah I plan on putting in a functional hood scoop too,
