Edelbrock head experts
Discussion in 'General Maverick/Comet' started by roblaw, Jun 4, 2020.
  1. Hotrock
    Munroe Falls, Ohio
    Sorry Frank, something that odd could only happen to you.
    stumanchu, mojo, Krazy Comet and 2 others like this.
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    That is a bit unusual!
    71gold likes this.
  3. roblaw
    roblaw Member
    !973 Maverick 302
    Thanks everyone for tips and insight. With the head off and on the ground with double layered, cellular cardboard under it, I placed a 1 foot 2x2 piece of pallet wood on all the valve springs separately and pushed on either side of wood. It took nearly all my weight in a push-up form to get them to move but they all did.
    I don't know if any were stuck to start with but I did whack the 2 springs in cylinder #1 1st with a rubber mallet (the suspect cylinder). I moved on to the push-up method because I couldn't tell if I was accomplishing anything.
    I put the head back on the block and adjusted the valves per the book. Now, the motor spins all the way around without binding. I did spin the motor after adjusting each cylinder's valves so I could narrow my focus in case of another bind.
    Now time to flip this thing over and plastigauge the journals and get the front sump oil pan and pump installed.
    Ya know this binding thing threw off my plan to just perform a leak down, swap parts and install it in the Mav. "best laid plans", I guess.
  4. 71gold
    glad you got it straightened out...:Handshake:
    and to think...this is just the beginning...:yikes:
