EFI 2.3L 4 banger test fit...
Discussion in 'Technical' started by Jamie Miles, Jun 22, 2008.
  1. chirt
    chirt Carlos Hirt
    Massachusetts
    Boy,, Am I glad these finally made to the U.S! :bananaman:2thumbs:
  2. Rando76
    Rando76 Member
    Claremore, OK
  3. 302mav76
    302mav76 Isaac Serna
    Monterrey, Nuevo Leon, Mexico
    '76 Maverick
    bump.
    Any news about the swap, Jamie?
  4. chirt
    chirt Carlos Hirt
    Massachusetts
    Jamie, Where are you? we want to see pics of the mounts installed!
  5. Jamie Miles
    Alto, GA
    I've had a few
    Sorry guys, got caught up in some other things last weekend and didn't have time to get to it. I will definitely get them installed this weekend!
  6. Jamie Miles
    Alto, GA
    I've had a few
    So, I toyed with them a little today. First thing I found, was that the bolt holes on the Brazilian frame mounts don't match up exactly with the existing holes in the Maverick. You can get two of the bolts in on either side, but the third (lower inner most) hole is about a 1/4 inch off. No big deal. The frame mounts also apparently bolt on the BACK side of the shock tower instead of the front side like I6 mounts.
    Second problem is, the right side engine mount hits the exhaust manifold, so it dosen't allow it to be bolted to the engine completely. It looks like a little grinding to both the mount and the exhaust manifold will provide the necessary clearance. The left side engine mount fits great, except one of the spots where a bolt goes into the block isn't drilled or tapped. The boss is there in the block, so I just gotta drill it and tap it so I can put the third bolt in.
    I loosely bolted everything up, and tried to drop the engine in, but I am starting to think it isn't going to be possible to use these mounts in a '69.5 Maverick. The Brazilian mounts set the engine about 2 1/2 or 3 inches further back in the engine bay, and the engine needs to be jacked up about an inch higher to get the rubber mounts seated down in the frame mounts, but the clearence just isn't there with the smaller '69.5 transmission tunnel. The transmission is hitting up against the top of the tunnel. Next weekend I think I am going to try swapping everything over to my '73 body and see how that works. The '73 is where this is all permanently going to go anyways, I was just using the '69.5 for test fitting and figuring out the wiring.
    I also toyed around with mixing and matching regular old V8 frame mounts used in conjunction with the original I6 rubber mounts and the Brazilian engine mounts. Something could definitely be made to work there, and that may be the path I take ultimately if I can't get ALL the Brazilian stuff to work right. And of course the very last ditch effort if absolutely nothing will be somewhat bolt in, will be going back and modifying the '93 Mustang mounts, which probably would have been the quickest and easiest in the first place, but hell, I'm having fun here trying all this foreign stuff.
    All in all, a fun and interesting day. I do have a few pics, but they will have to wait till tomorrow afternoon. I just got home, and I'm totally beat, and have to be at work at 6 in the morning.
  7. Comet155
    Comet155 Member
    Very interesting. Look'in good! :tiphat:
  8. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Glad to hear of the update, even if it wasnt the best one possible
  9. 302mav76
    '76 Maverick
    you'll have better luck with the 73. Remember that Mavericks didn't appear in Brazil until 1973 maybe that's why it didn't work properly. At least you got 2 choices for the swap.
    Thanks for the news Jamie!
  10. chirt
    chirt Carlos Hirt
    Massachusetts
    What he said!:thumbs2:
  11. Hanks351
    Hanks351 2much torque club!
    Brazil
    1977 Maverick GT
    That's true, why don't you import a brazilian Maverick??:thumbs2:
  12. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Can't you just use chain for motor mounts?
    LOL I kid, I kid...
  13. soooulpower
    Mapleton Depot, Pennsylvania
    Any new updates? Inquiring minds want to know!
  14. Jamie Miles
    Alto, GA
    I've had a few
    Didn't have time to get to it this weekend. Had to pull a 5.0/AOD out of an '85 Town Car so it can be hauled off to the scrap yard next week, and been helping my brother strip his '72 Grabber to get it ready for body work. Next weekend I plan to get back on it full force.
  15. soooulpower
    Good to hear. We're all puling for you, Jamie!
