EFI conversion project . . .
Discussion in 'Technical' started by mashori, Sep 2, 2011.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    as for the siemens deka injectors, there is a short style, long style EV1 and long style USCAR.
  2. mercgt73
    mercgt73 Member
    Brain food:
    http://www.hptuners.com/forum/showthread.php?t=25253
    http://www.gtsparkplugs.com/InjectorSizeCalc.html
    http://www.injector.com/injectorselection.php
    www.fordracingparts.com/download/charts/Fuel_Injectors_and_Adaptors.pdf
    These links will explain the sizes, connector nomenclature and other stuff. It is mostly Ford info, but you can apply it to the Deka injectors.
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    So basically I run the new fuel lines, install the throttle body, hook up throttle cable, hook up the fuel pump, install the EFI intake, fuel rails and hook up the wiring harness and computer and I'm good to go? what's gonna be the toughest part of the installation?
  4. safado
    safado Member
    West Phoenix, AZ
    the install is easy.. the tuning is where you get slowed down on.. how built is the engine?
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    it's a low compression (8.7:1) 331 engine. stock block, high performance pistons and rods and AFR heads. It does 350hp to the tires right now on the last dyno with a T5 tranny.
  6. safado
    safado Member
    West Phoenix, AZ
    What cam you running.. Numbers are high for that combo..
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    the best time without nitrous in the 1/4 was 12.965 sec at 109.84 mph
  9. maverick75
    No they're not. He's running 185cc AFR heads. They make great power, just wait till he adds boost into the mix.
  10. safado
    safado Member
    West Phoenix, AZ
    guess, we will find out on the dyno day.. I believe he is coming.. I had a 9.5 comp 302 with Windsor SR 200cc heads, with the "POS" E303.. never knew the HP levels. but the car on a radial would go 12.8 at 112.. and I highly doubt it was in the 400 at the wheels range.. but hey, you'll never know.. the dyno is just a tool.. the track is the real measuring stick..
  11. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    How are you going to run your fuel lines? Those have been the biggest quandry for me, I am looking at fitting a mustang tank in, and running new hard lines, and as an added bonus I will have an easier time with my dual exhaust.
  12. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I had an early style mustang gas tank modified with a relocate pickup and baffles. So it shouldnt be too hard on my setup.
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    accufab arrived, could have gotten it used for $200, got a brand new one (well, at least it was never used) for a little over $200.
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    and got the fuel injectors for $330, not too bad, brand new. I think I should be ok going with 60lb injectors. Don't think I can make more than 500 hp on this engine with the supercharger anyways.
  15. jayss10
    jayss10 This is Minerva
    INDIANA
    1971 MAVERICK,73 GRABER CLONE
    hey mo make sure you list prices with this build ok im thinking of doing the same id like a mid 11 sec car
