EFI conversion project . . .
Discussion in 'Technical' started by mashori, Sep 2, 2011.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    So these were the hose ends I got that attach to the rubber hose which is rated at 250 psi but according to one reply by a summit tech person it's not listed nor advertised as fuel lines.
    This is what I got instead, hose ends that just push into a nylon braid hose, summit brand.
    The bill for the hose ends and hoses was $355.
    The bill for the aluminum hose and other fittings and fuel filters was another $300 or so.
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    since I already have the EFI intake with those injector bongs welded on, can I just install that one and somehow plug those bongs without too much hassle? It would help because that's one less step I have to do in order to get the car ready for EFI....and seeing as to how every time I pull my oil drain plug on the engine I find new interesting pieces I'm sure it won't be long before I have to pull the intake again....
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    next things on the list, wiring harness and sensors. Any recommendations? The wiring harness we were thinking of sourcing from a donor mustang....
    Bry mentioned that the sensors shouldn't be too pricey (throttle position, water temp, air temp), are there any brands that are more recommended than others....
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    any thoughts on best source of engine harness? maybe an explorer? we were thinking of individual coils....megasquirt 3 should be able to handle that....
  5. Bryant
    how about a wireless harness?
  6. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    If you are running individual coils make sure you use the MS3x daughterboard, that is about the only way you will make the individual coils work without a bunch of extra nightmarey work, http://www.diyautotune.com/catalog/megasquirtiii-ms3x-expansion-card-p-434.html
    Its even setup to work with a external map sensor so you can use the internal unit as a barometric sensor
    But if you are going to go the route with a megasquirt why dont you buy the wiring harnesses from DIYautotune?
    The wires are already individually labled all you do is position them and cut them to length.
    Here is the main harness
    http://www.diyautotune.com/catalog/1239-megasquirt-wiring-harness-ms1-ms2-ms3-ready-p-43.html
    Here is the MS3x harness
    http://www.diyautotune.com/catalog/1239-megasquirt-wiring-harness-for-ms3x-p-451.html
  7. mercgt73
    mercgt73 Member
    That's interesting, cause Russell brand TwistLok is OK for fuel up to 250psi.
    http://www.russellperformance.com/mc/hose/twist-lok.shtml
    Notice the red collar is just pushed on, not screwed on. The black fitting version, although, does not use the collar.
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    but you see, it doesn't mention that it's for fuel...at least I don't see it.
  9. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    So I don't need a wiring harness with all the connectors? I can get the connectors separate?
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  11. mercgt73
    mercgt73 Member
    It says it in the description. :huh:
  12. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I missed that...I guess the summit one just isn't fuel compatible. Wish I had seen this, probably would have been much easier to work with this. But at least the braided stuff I got wasn't too expensive.
  13. mercgt73
    mercgt73 Member
    I freaked when you said the TwistLok was not for fuel, because I am planning my whole fuel system to be TwistLok. Guess I just need to be sure to stick with Russell or atleast check to make sure it is fuel compatible. The braided stuff works fine too, my Mustang is plumbed with it. :yup:
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    can I just control fuel flow with my MS3 for now and set it up for ignition control at a later time? So basically have it control the injectors and cont with my current distributor/6Al2 ignition?
  15. markso125
    markso125 Member
    Lewiston Ut
    Yes you can you can get new plugs for everything from the IAC valve too the Injectors
    http://www.diyautotune.com/catalog/460-piece-weather-pack-kit-p-379.html
    http://www.diyautotune.com/catalog/fuel-injector-connector-bosch-ev1-p-111.html
    Yes you can control the injectors with just the MS3. The other option if you wanted too wait on the SEFI setup and wanted the distributorless ignition is you can run a wasted spark setup on just the MS3.
    You can either setup an EDIS module running off of a crank trigger, or you can use an explorer module to activate your ignition sequence. Either by a ford EDIS module or activated by the MS3 unit itself.
