efi fuel filter question
Discussion in 'Technical' started by bomrat, Sep 11, 2014.
  1. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    hi, i got trash in my injectors again.. the setup i have is:
    the original pickup in tank
    fuel filter
    fuel pump
    fuel filter
    at last injectors
    HAMBURGERS 3341 is the type filter i have, looks like 15 microns on both.
    http://www.summitracing.com/parts/ham-3341
    do i need a smaller micron? or a different filter
    if i remember they are stainless screens in both not the paper element.
    I'm cleaning out my injectors tomorrow evening and try it again
  2. Krazy Comet
    I dunno what the flow rate or filter ability is for the stock EFI filter but that's what'd be on mine...
    The stock filter worked on my supercharged Marauder that was pushing around 50 PSI into 36Lb injectors...
  3. 71Mavrk
    71Mavrk Member
    Nevada
    I would look at the condition of the line between the pump and the injector. Are they rusty originals or deteriorating rubber?
    Also, what is your return line? Is it going back to the tank or are you looping it back into the feed line? What is the condition of this line?
    Micah
  4. Bryant
    ive always used a 100 micron prefilter and a 10 micron post pump filter. what is plugging up the injectors? rust? rust will go through all metal mesh type filters. i use a paper element in the post filter. i have used the aeromotive ones and the mallory ones with great success.
  5. bomrat
    bomrat Member
    i have all new lines from front to back. i installed 1/2 aluminum lines both feed and return.
