EFI Fuel Lines & and AOD
Discussion in 'Technical' started by 71Mavrk, May 8, 2014.
  1. Mavman72
    I would not run the fuel line in the tunnel...If you have a driveshaft/ 'u' joint failure at speed. You could have fuel under pressure spray onto hot exhaust components causing a fire. Theres a reason ford ran the feed line far away from the tunnel.
  2. 71Mavrk
    71Mavrk Member
    Nevada
  3. 71Mavrk
    71Mavrk Member
    Nevada
    Sorry to pester you guys, but resolving the fuel line issue is holding up installing the engine.
    Either of you find an invoice or a part number that I can refer them too?
    Any AOD pictures that I can review to make sure I have no issues?
    Thanks
    Micah
  4. Dave B
    Sorry, it was a long weekend, I got side tracked...send me a PM so I don't forget, and I'll get some when I get home from work tomorrow.
