Efi Update Pics
Discussion in 'General Maverick/Comet' started by gsjohnson, Feb 10, 2003.
  1. Mavaholic
    That upper intake is the bigggest reason I dont like Fords EFI. Why cant they make a straight shot with the throttle body mounted on the front? I dont know much about the EFI set up but wouldnt this be possible? It would certainly make installation easier. Is there anything other than the throttle body mounted on the upper intake? I think I'll write to Eddlebrock and see what they can do.
  2. 76 Mav
    76 Mav Reformed Camaro junkie
    Cobb County Ga.
    76 Mav , 70 Galaxie ,04 F350,03 Mustang,03 F150
    Custom intakes are possible if your a good fabricator ... Or you can simply buy one, But be prepared to drop about 2 grand ... All the upper intakes do on an efi is distribute the air flow equally to all the cylinders and because its efi it has nothing to do with air/fuel mixture thats done in the lower intake, If you look at the GT-40 intake its just a series of seperate tubes attached to a box type thing that is attached
    5042A Custom Fabricated sheet metal intakes. Runner length and diameter optimized for specific application. Front or side entry throttle body available. - $2,600
    d to the throttle body ...
    http://www.seanhylandmotorsport.com/imag/shm46_pg3_sheet.jpg
  3. Narcoleptic
    Narcoleptic Member
    Chico, TX
    '77 Maverick 4-Door
    It kills low-end torque. Comp Cams makes a box upper or you could get a Spyder intake. (90 degree elbow on a Victor Jr. Intake)
  4. radmav76
    radmav76 Member
    Toledo, Ohio
    1976 maverick soon to be 460 powered...project on hold.
    Some of the earlier fox bodied mustangs used a smaller diameter power brake booster. It's very popular on a bigblock swap for the fox bodied cars for those who still want power brakes. You could probably still find them in salvage yards.
