Eileen--Revisited
Discussion in 'Technical' started by scooper77515, Jun 14, 2005.
  1. 74merc
    74merc computer nerd
    1974 Comet
    I wouldn't cut them period, but that's me.
    Swapping them should help a bit, and I'd make plans to replace the springs if the problem persists, but I wouldn't cut them.
  2. Craig Selvey
    You are assuming the springs are the only problem. It could be the perches, the saddles, the a-arms, control arms, different tires, shackles, sidepipes........or anything that could be causing this. I would not cut anything......just swap them and see what happens. If it is the same after swapping.....then it wasn't the springs.
