electric fan questions...
Discussion in 'Technical' started by NorCalMaverick, Mar 14, 2014.
  1. vvr210
    vvr210 Member
    Vista,CA
    Heres the part number for the sensor. Low speed comes on at 180 and fast speed at 188 61318361787
    I got mine off rockauto for 11 bucks
    http://www.rockauto.com/catalog/moreinfo.php?pk=1134042
    This is the part number for the temp. switch housing 61 13 1 378 410
    And you will need 3 of these wiring pigtails that plug into the switch. 61 13 0 007 441
    These are straight pigtails. I got ones with a 90 degree bend but I cant find the part number maybe you can do a little searching on http://www.bavauto.com/shop.asp I bought the housing and wires off this website and the switch off rockauto.
  2. NorCalMaverick
    NorCalMaverick Member
    Pinole, Ca
    1974 Ford Maverick 2 Door
    ok cool what motor does the fan I need come on?
  3. 71gold
  4. 71gold
    3.8...:bouncy:
  5. NorCalMaverick
    Pinole, Ca
    so I picked up my taurus e fan, I do need help on how I should trim the shroud for a better fit. I've also heard to make a bigger rad like the one I recently bout you can trim the rad support? anyone done that? also going to head out today and snag my volvo relay from pick n pull, as always thanks for the help!
  6. NorCalMaverick
    Pinole, Ca
    also this is holding up my rad from fitting, what I mentioned in the reply above this one.
  7. mercgt73
  8. NorCalMaverick
    Pinole, Ca
    thanks, that's exactly what I needed. I'll just look into modding the rad support now
  9. 71gold
    the fan shroud needs to be installed...upside down.
