Electric Ignition not working
Discussion in 'Technical' started by Wilsond3010, Apr 11, 2012.
  1. cody674
    cody674 Member
    1972 Ford Maverick
    http://www.hot-spark.com/ this is similar to what u r running and what im running.... if the coil is good and u put the point back in try the condenser and did u try check to see if u had fire at the points hint if u get fire at the points but not out of the coil and the coil is fine its the condenser
  2. Wilsond3010
    Wilsond3010 Member
    Regina, SK
    1970 Maverivck
    Thanks Guy's finally got it running tonite. We put a new coil in and the new ignitor and it's running.
    And it sparked straight away. We changed all but 1 spark plug due too it not budging and worried we broke it off completely
    So not i just need to get it tuned and then start cleaning up the engine bay itself before moving onto the rest of the car and figuring it out
    Balls joint's and alignment next but alot people say it's such a pain just take it in and get it done
  3. 71gold
    who are these people...:huh:
    that's the fun.... doing it yourself...:yup:
  4. Wilsond3010
    Wilsond3010 Member
    Regina, SK
    1970 Maverivck
    lol true true
    I think by neighbour as he know's he'll end up helping me.
    So would you guy's recommend spraying penetrating lube or wd40 into the 1 spark plug that won't come out
  5. mojo
    I don't see where putting penetrating oil in the plug area will hurt anything. That's what I wud do and let it soak overnite. Also, I use anti-seize compound on my plugs when I install them. I don't have any issues removing them "iron heads".
  6. Wilsond3010
    Wilsond3010 Member
    Regina, SK
    1970 Maverivck
    Ok so i got the electronic conversion done and it's working but I was going to replace the spark plug wires but the connectors are different (I know this is a stupid rookie question)
    Old one
    New One
